Shorter accessory belt? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-10-2015, 12:02 AM Thread Starter
Weatherlite's Avatar
Garage
Installed an upgraded alternator. They recommended installing a 1" shorter belt to compensate for the smaller pulley. I've been looking, but I can't find anything. My belt just shredded today so I need to change it and soon, but the next size down I can find, or the parts folks, is a full three inches shorter. I don't think that will work. Anyone know any sources?
Weatherlite is offline
post #2 of 12 (permalink) Old 04-10-2015, 12:27 AM
Administrator
Zmann's Avatar
Re: Shorter accessory belt?
thats silly who's alternator ??
you can space the alt up to take up slack if need be
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 12 (permalink) Old 04-10-2015, 12:44 AM Thread Starter
Garage
Made by Mechman. They use a smaller pulley to improve idle performance. I looked at just about every HO alternator maker out there and they all do that, with a few exceptions. No worries now though. I just released tension and folded the belt over to measure....I've actually got four inches of excess, so a 3" shorter belt should do me just fine.
post #4 of 12 (permalink) Old 04-10-2015, 02:59 AM
Administrator
Zmann's Avatar
there is no way the smaller pulley gave you the need for a 3" shorter belt
many of us use smaller Alt pulleys with no mods mine has 3/8 spacers to put the belt tensioner back where it would ride normally but i could remove them and be fine
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 12 (permalink) Old 04-10-2015, 06:20 AM Thread Starter
Garage
Hmmmm.....maybe the previous owner installed a longer than stock belt. Thinking I'll take it off tomorrow, cut it (it's trashed anyway) and measure to see what I've got now. Could be that it's got a 128" or something like that on there!
post #6 of 12 (permalink) Old 04-10-2015, 03:08 PM
Administrator
Zmann's Avatar
that might explain it but i would be surprised if it would have worked being that much longer
grab the part # ? i think i have an OEM belt i could measure
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 12 (permalink) Old 04-11-2015, 12:45 AM Thread Starter
Garage
Pulled it today and measured it. No part numbers anywhere on it...rubbed off I guess. Cut then measured it. Comes out to 125 inches. Stock is 125 or so inches (125.3 or 125.7 are the two depending on who makes it) I definitely have three extra inches to play with with the new alternator installed so I'm going with a 122.3 (next closest size).
post #8 of 12 (permalink) Old 04-11-2015, 01:08 AM
Administrator
Zmann's Avatar
something is wrong i wonder if any other pulleys were changed or if the routing is off ?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 12 (permalink) Old 04-11-2015, 03:40 AM Thread Starter
Garage
I'll double check the routing to be sure, but it didn't look like it was routed incorrectly. As for different sized pulleys, don't know.
post #10 of 12 (permalink) Old 04-11-2015, 04:09 AM
Administrator
Zmann's Avatar
not sure it is even possible to route it incorrectly but here is a pic
DTR's Donation page
RIP DTR Ron
Zmann is offline
