please help, truck died while driving, won't crank. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-09-2015, 04:43 PM Thread Starter
I was driving to work this morning and my truck died, it just cut out clean. No sputtering, nothing, just boom, dead. Then in my message center TBC FAULT came up. I can't get it to a crank over or anything. I have been checking fuses, found nothing wrong, checked relays, checked for power at the starter. It is a 2005 Ford F250 with the 6.0L and I am lost. Any help would be appreciated.
brendon is offline
post #2 of 6 (permalink) Old 04-09-2015, 04:45 PM
"Slap hands slap hands"
FlossyB's Avatar
Re: please help, truck died while driving, won't crank.
Get a scanner on it and see what codes it's throwing.
JB
FlossyB is offline
post #3 of 6 (permalink) Old 04-09-2015, 04:48 PM
matthewd11's Avatar
I have found that it throws TBC fault on dash when batteries are very low. Check batteries first. Alternator may have failed.
matthewd11 is offline
post #4 of 6 (permalink) Old 04-09-2015, 05:01 PM Thread Starter
Scanner won't link, I found a wire on the pass side fender that if you put power to it allows the truck to crank. It cranks very strong.
brendon is offline
post #5 of 6 (permalink) Old 04-09-2015, 10:17 PM
I Just Break Stuff
Check your cigarette lighter fuse.
You'll get the TBC fault if you keep on cranking for an extended period of time. Not sure why, but I get it every time I open my hpo system up and re prime it.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #6 of 6 (permalink) Old 04-10-2015, 11:09 PM
'04psthrottlejockey
'04psthrottlejockey's Avatar
I'm going through the same thing myself right now. However I can give you some insight, check your harness feeding your fan clutch. Make sure it is not cut and also try unplugging it and try to crank. If you don't have luck with that as I didn't then unplug the center plug on your PCM next to your drivers side battery. If it cranks then it's either a chaffed wire on your engine harness or a shorted voltage reference sensor. Does your fuel pump turn on when cycling your key to run?
'04 F250 6.0 RCD EGR delete, diamond eye 4"turbo back, AFE stage 2 cold air intake, Livewire TS, Warren Diesel Injection 190cc stock nozzle injectors with upgraded solenoids, FASS Titanium series fuel pump. 4" procomp suspension lift with extra overloads on rear.
'04psthrottlejockey is offline
