6.0 lots of grey unburnt fuel smoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 28 (permalink) Old 04-08-2015, 05:48 AM Thread Starter
joshjonquet 1's Avatar
Ok so I haven't been on in awhile but I've got an issue that I think I kniw the answer to but would like some more opinions. Truck is an 05 155k deleted no studs yet pretty stock. Truck has new 550 miles warren diesel stock injectors. Ran great for the first 549 Miles then all of the sudden started running like crap and acting like it had an injector issue and pooping unburnt fuel smoke thick and grey. Fuel psi is where it should be at around 60 psi. Has hi flow banjos. Icp is around 1 200 psi cold at idle and never below 600 psi at op temp at idle. and ficm voltage has never dipped below 48.5 volts. So as you can see I'm kind of stumped I've always had awesome luck with warren diesel injectors so I find it hard to belive that they are my issue but if it is I guess they are still warranted so not a huge deal.would just like to get some input on this before I tare it back down again. Any help is greatly appreciated
joshjonquet 1 is offline
post #2 of 28 (permalink) Old 04-08-2015, 06:03 AM Thread Starter
Re: 6.0 lots of grey unburnt fuel smoke
Also forgot to mention no codes at all and I already pulled the injectors thinking that I may have fd up an oring on install. Not the case all orings were perfect.
post #3 of 28 (permalink) Old 04-08-2015, 07:22 PM Thread Starter
Anyone ?
post #4 of 28 (permalink) Old 04-08-2015, 07:27 PM
Jackleg Mechanic
mastrkee's Avatar
how's your boost pressure looking?
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #5 of 28 (permalink) Old 04-08-2015, 07:38 PM Thread Starter
Boost seem pretty normal to me 25+ with a load on it
post #6 of 28 (permalink) Old 04-08-2015, 07:42 PM
Jackleg Mechanic
mastrkee's Avatar
that should do it. check all wire plug connections, if their all good I'd have to agree there is an injector problem.
Jeff
mastrkee is offline
post #7 of 28 (permalink) Old 04-08-2015, 07:42 PM Thread Starter
Sometimes when you first start it it just kind if starts out with a nice little blue haze then turns into full blown smoke. It does seem very doggy in the low end but if you get on it it runs like what it should except that the smoke doesn't clear up at all
post #8 of 28 (permalink) Old 04-08-2015, 07:43 PM Thread Starter
I've checked and double checked everything I can think of twice
post #9 of 28 (permalink) Old 04-08-2015, 07:47 PM
Jackleg Mechanic
mastrkee's Avatar
What kind of tuning is in it?
Jeff
mastrkee is offline
post #10 of 28 (permalink) Old 04-08-2015, 07:50 PM Thread Starter
Sct livewire ts with just the canned tunes at the moment. Does the same thing stock or tuned
