Window won't roll up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-08-2015, 05:20 AM Thread Starter
Src48's Avatar
My passenger window will roll down but not up. Check motor it's good. Put a new switch in passenger . Windows on the track. Still can't get it to roll up
Src48 is offline
post #2 of 4 (permalink) Old 04-09-2015, 03:04 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Window won't roll up
Check your drivers side switch. Pull it out and tap on it lightly while trying to roll it up. Had that issue on an 03 once. Wouldn't go up at all with either switch, but had a faulty driver side switch. Could tap on it and it would work. Apparently power goes to the drivers side before any other doors.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 4 (permalink) Old 04-09-2015, 03:32 AM Thread Starter
Src48's Avatar
Tap onto the bottom where the wires go in?
Src48 is offline
post #4 of 4 (permalink) Old 04-10-2015, 03:46 AM
Big dumb redneck
6speedSD's Avatar
Garage
Yea, like snap the switch cover off the door panel, and tap the bottom.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
