Scangauge II First Time EBP and ICP Two Part Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-07-2015, 03:57 AM Thread Starter
Yep, I finally bought one. No one should really be allowed to buy a 6.0 PSD without one of these (unless they already have a better monitoring system) Yes, for almost a couple years I've been using the Edge for basic monitoring, but the SGII offers so much more.
Now for the questions:
First, I don't get any EBP reading. Yes, I have verified the codes are entered correctly. What gives? Will a bad sensor not produce a reading? Did early trucks not display EBP?
Next (of course) the ICP. Floored the IPR duty cycle will go to 75% and the ICP will produce around 3640 psi. Is this high enough? Has anyone seen a higher IPR reading on early trucks? I've read the newer trucks will go to 85% and 4000+ psi. By the way, at warm idle it's 24.2-24.6% IPR every time. Basically, is my HPO system performing sub-par?
Thanks!
post #2 of 6 (permalink) Old 04-07-2015, 04:36 AM
Re: Scangauge II First Time EBP and ICP Two Part Question
Your early truck may be using a programmed EBP reading. 75% and 3640 psi looks good to me. The max you will see is about 85%.
lenzhotrod is offline
post #3 of 6 (permalink) Old 04-07-2015, 04:42 AM
i think your hpop system is doing fine. It reads just about the same as mine does. 84% is the max reading for the IPR and your pump can hit 3600 psi at 75% of the desired pressure. sound pretty good.
03 Excursion, Banks turbo back, K&N intake, SCT sf2, Scangauge 2, 285/70R17 on Eagle alloys, purchased June '10
robs97z28 is offline
post #4 of 6 (permalink) Old 04-08-2015, 03:50 AM Thread Starter
Thanks guys. I'll admit I'm a bit paranoid about the HPO system owning one of these. As you can see in my sig, I put a lot into it last year. In addition to what's listed I also put all now oil rail nipple O-rings and new O-rings in the top of the injectors.
Hmmm, interesting. I'll have to do some searching on this...
post #5 of 6 (permalink) Old 04-09-2015, 03:06 AM
Big dumb redneck
6speedSD's Avatar
Garage
Some of the early models had the EBP written out in the strategy. Meaning it doesn't even use that reading.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #6 of 6 (permalink) Old 04-09-2015, 03:32 PM Thread Starter
Yep, so my searching has since revealed. Apparently there was an update/flash that eliminated the sensor input and instead used empirical values where needed.
