Waterpump question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-03-2015, 07:07 AM Thread Starter
Weatherlite's Avatar
Garage
Waterpump question
Simply, how can I tell what size I have on my engine? According to one website which sells the pumps, you can tell by some of the letters/numbers in the VIN. According to my local dealer, that is usually true, but is not always the case and the only real way is to take a look at the pump. However, being a parts guy, and not a mechanic, he didn't know if there was an external way to determine this. So, other than pulling the pump and measuring the wheel, is there another way to find out if I have a 90mm or 100mm pump?
Weatherlite is offline
post #2 of 6 (permalink) Old 04-03-2015, 12:13 PM
"resident smarty pants"
Re: Waterpump question
What year model truck? Do you know when the engine was built?
The change happened between July and October of 2003.
Mark
bismic1 is online now
post #3 of 6 (permalink) Old 04-03-2015, 04:53 PM
'04psthrottlejockey
'04psthrottlejockey's Avatar
It's always helpful if you know the counter person. Some places will get both pumps so you can compare at the counter and send the wrong one back. Of course if you're ordering online you'll have to pull the pump and measure from the base of the mounting flange to the face of the hub where the pulley mounts.
'04 F250 6.0 RCD EGR delete, diamond eye 4"turbo back, AFE stage 2 cold air intake, Livewire TS, Warren Diesel Injection 190cc stock nozzle injectors with upgraded solenoids, FASS Titanium series fuel pump. 4" procomp suspension lift with extra overloads on rear.
'04psthrottlejockey is offline
post #4 of 6 (permalink) Old 04-03-2015, 05:16 PM
Administrator
Zmann's Avatar
the reference to vin codes in here may help Bullet Proof Diesel Water Pump for 6.0L Diesel
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 6 (permalink) Old 04-04-2015, 12:54 AM
Using vin codes assume that the front cover is original, if not all bets are off.
lenzhotrod is offline
post #6 of 6 (permalink) Old 04-08-2015, 01:50 AM Thread Starter
Garage
Yeah, I had seen that VIN reference before, but have been told to not trust it since Excursions tended to get leftover parts....ie, there was a 2003 front cover left over and they used it even though the Ex was a 2004.25 and up model. I have the 4EC vin, which means I SHOULD get the 100mm, but I don't know when the engine was built nor do I know if the front cover was ever changed....though I would hope if it were then it got a newer one put back on. Well, I'll be doing head gaskets soon enough.....may as well just pull the pump and measure while she's down rather than play the guessing game now.
