04 high pressure oil problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-31-2015, 02:28 AM Thread Starter
turborangerdude's Avatar
Send a message via Yahoo to turborangerdude
I have an early 04 I took a part put in oil cooler did an EGR delete changed out a couple injectors. I had all the injectors out and clean them put them back in the truck runs most of the time but every once in a while it will die and then will not build oil pressure but then out of the blue it will start building oil pressure again it'll run fine for hours it'll die but start right back up but every once in awhile it won't does anybody have any ideas what could be causing this
04 F-350 6.0 dually egr delete strait piped to 6 inch dual stacks
05 F-350 6.0 srw egr delete 58v ficm and turbo back 4" with 6" tip
turborangerdude is offline
post #2 of 13 (permalink) Old 03-31-2015, 03:35 PM
Re: 04 high pressure oil problem
How many miles has it been since you had it back together? If it's been a few, it sounds like an IPR problem to me. How does the wiring/plug look? Have you tried replacing the IPR?
post #3 of 13 (permalink) Old 03-31-2015, 03:50 PM
Just replaced the ipr..he would clean the ipr re-re-install it and it would run again. So it got replaced. (Also working on this gremlin machine)
focidriver is offline
post #4 of 13 (permalink) Old 03-31-2015, 04:10 PM Thread Starter
It has run a total of maybe 6 hrs of and on in the shop can't keep it running long enough to even drive it longest it has run at 1 time is about a hour and a half in between running and dying and restarting
post #5 of 13 (permalink) Old 04-01-2015, 05:07 AM
Do you have a way to monitor ICP and IPR? If not, I'd get one. I just got my Scangauge II last week. I'm pretty geeked.
post #6 of 13 (permalink) Old 04-01-2015, 05:44 AM
whistle tits
ghohouston's Avatar
Did you replace the injector o rings?
ghohouston is offline
post #7 of 13 (permalink) Old 04-02-2015, 03:13 PM Thread Starter
Yes I havery a way to monitor icp and ipr when it won't start it usually runs around 100 psi I did not replace injector orings what has me so confused is it is so random as to when it will and won't start I have tried pressure test but I cant find a leak
post #8 of 13 (permalink) Old 04-02-2015, 09:58 PM
IIvonnyII's Avatar
Replace the injector o rings. Could have pinched or torn one on installation
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #9 of 13 (permalink) Old 04-03-2015, 06:14 AM
When it does run, what's the IPR duty cycle at idle?
post #10 of 13 (permalink) Old 04-03-2015, 07:32 AM
You may have your HPOP internally rotating, a known problem with 03 and 04's. Watch your ICP pressure for sudden loss of pressure.
lenzhotrod is offline
