Just wanted to see what u guys thought about this article - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-30-2015, 11:11 AM Thread Starter
Installing Head Studs Without Removing The Cylinder Head: Diesel World
toulakid is offline
post #2 of 7 (permalink) Old 03-30-2015, 03:33 PM
Administrator
Zmann's Avatar
Re: Just wanted to see what u guys thought about this article
i think it's a cummins
i wouldn't use the two at a time procedure on a 6.0 i would do 1 at a time and bring it to full torque and I would change them in the torque pattern sequence
then I would still feel like I half assed it but would be happy the TTY bolts were gone
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 7 (permalink) Old 03-30-2015, 04:00 PM
Sounds like a good idea. One of my friends is Ford mechanic since 86. I'll run it by him.
Cookieone is offline
post #4 of 7 (permalink) Old 03-30-2015, 07:55 PM
Slated4Greatness's Avatar
But if the head or the block aren't good and flat it won't seal no matter how much you torque them.
Slated4Greatness is offline
post #5 of 7 (permalink) Old 03-30-2015, 09:17 PM
I`ve Bullet Proofed 6 6.0 L`s and added ARP head studs. 2 I had to pull the heads as they were broken, other 4 I installed studs one at a time in order and torqued as I went. They have been in service for quite a while and NO problems. Bill Mad Macs Repair
97 F250 7.3 PSD SCLB 4x4 4.10L AUTO, DIAMOND EYE EXHAUST,,DIY 6637. E99 intercooler. 01 4R100 (Built), PCM DPC 422, D-66, 180/80 injectors, T-500 HPOP, E-fuel, DP-tuner F6 V2 chip with Jodys tunes, 290,000 and still going strong. Also live tuned by Jody
BillMcIntire is offline
post #6 of 7 (permalink) Old 03-31-2015, 03:45 PM
I did it to mine. It's a huge PITA, and I do feel like it isn't as good of a job as it should have been. I just couldn't sink any more money into the project at the time. I think this is possible, but if I ever do another one I'll remove the heads.
That said, I haven't had any problems. Even did a couple 80 MPH uphill WOT pulls while towing my flat nose 7k trailer.
When replacing one fastener at a time I don't think torquing that one stud to its third stage torque is a good idea. Actually, I think it's a very bad one. I say this because when I removed some of the TTY bolts they were not adding much clamping force at all (broke free easily when removing). So if all of the TTY bolts are holding much less clamping force than they should be, installing one stud and torquing it to its final torque might cause problems. To do mine, I went in order, removed the bolt, installed the stud, and then torqued to its first stage, then moved onto the next one, etc. etc. When all studs were installed and torqued to their first stage, I went through the next two stages of torquing normally.
post #7 of 7 (permalink) Old 04-02-2015, 03:36 AM
I brought them up to torque in 3 steps.
