Time crunch no start no crank - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-27-2015, 10:14 PM Thread Starter
When I attempt to start my truck all systems start up fine, no codes, when I turn the key to crank it makes one click but doesn't crank...
Anyone have a quick checklist to run through? I Tried starting in neutral, no go, checked starter fuse, all good. Im racing the clock for parts store being open.
I don't know how to jump the starter to test it as I've seen referenced on other threads.
I also tried swapping a few relays around no dice
2004 CCSB Lariat 4" lift, 35's, Edge CTS Insight, SCT X3, 4" Diamond Eye turbo back cat delete with muffler, pioneer double din Nav headunit.
abrown3mtg is offline
post #2 of 6 (permalink) Old 03-27-2015, 10:27 PM
Re: Time crunch no start no crank
Check your battery cables. Make sure they all tight and clean connections.
95powerstroke82 is offline
post #3 of 6 (permalink) Old 03-27-2015, 10:31 PM Thread Starter
All good on that front (from previous recent battery drain issue I fixed)
post #4 of 6 (permalink) Old 03-27-2015, 10:48 PM
cfherrman's Avatar
This shows you one way to jump it.
6.0 Powerstroke base oil pressure checks and known issues: 6.0 Powerstroke base oil pressure checks and known issues - YouTube
06 f250 personal, 05 bmw x5 wife, 14 f350 srw work
Originally Posted by Zmann View Post
it's a 6.0 nervous goes with it
cfherrman is offline
post #5 of 6 (permalink) Old 03-28-2015, 06:19 AM Thread Starter
Problem ended up being a broken electrical connector going to the starter. Discovered it while pulling the starter this evening....
post #6 of 6 (permalink) Old 03-29-2015, 09:13 PM Thread Starter
Does anyone know if there is an easy to source replacement cable? I don't have the tool to crimp on a new end.... Debating driving the 100 miles to have it done or trying to find a simple replacement.
Thank you
