seriously thinking about doing a diy coolant filter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 28 (permalink) Old 03-27-2015, 01:14 AM Thread Starter
cfherrman's Avatar
I checked on a 3/8 npt filter head at the supply store, 32 bucks plus a filter thats probably 3 bucks, so i have some things i dont like about the current setups, mostly about the extra hoses around looking like a cobbled up setup. I think i could do it either for the same amount or less as the 6.0 specific product. Does anybody have any reservations about this? Is there other places hoses could be hooked into? Lastly, does it have to be a bypass system? Thanks
06 f250 personal, 05 bmw x5 wife, 14 f350 srw work
Originally Posted by Zmann View Post
it's a 6.0 nervous goes with it
cfherrman is offline
post #2 of 28 (permalink) Old 03-27-2015, 01:33 AM
Re: seriously thinking about doing a diy coolant filter
I did my own. The reason they are bypass is because there are no filters to handle the flow needed and filter fine enough at a reasonable price. Also you can plug the filter without downing the system.
lenzhotrod is offline
post #3 of 28 (permalink) Old 03-27-2015, 03:08 AM Thread Starter
cfherrman's Avatar
So if i find a high flow filter with a pressure bypass i could if i wanted too?
post #4 of 28 (permalink) Old 03-27-2015, 03:33 AM
Weatherlite's Avatar
Garage
You could, but it's not going to really be as effective believe it or not. If you really want a full flow inline filter, I would go with one in line with the heater core. That way, if/when it plugs, you won't run any risk of hurting the engine.
Weatherlite is offline
post #5 of 28 (permalink) Old 03-27-2015, 05:31 AM Thread Starter
cfherrman's Avatar
Yeah thats what i was think of except it wouldnt filter when the ac is on
post #6 of 28 (permalink) Old 03-27-2015, 01:46 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
i think the heater core valve is open on the normal AC setting to enable blending the air, but it's closed on max ac. at least that's how my truck behaves from in the cab
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #7 of 28 (permalink) Old 03-27-2015, 05:19 PM
Administrator
Zmann's Avatar
that's is normal for all our trucks
like stated max ac is the only time the heater is blocked if you don't like that for your filter just install before the shut off valve
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 28 (permalink) Old 03-27-2015, 05:48 PM
All done now
Arisley's Avatar
I think there is coolant flowing through the heater core even if you are in max A/C.
I never saw a valve in there when I replaced my heater core.
There is a mod where you can install a valve. I think Bob at Dieselsite has one.
Arisley is offline
post #9 of 28 (permalink) Old 03-27-2015, 06:01 PM
Turd-250's Avatar
i was just talking about the vacuum operated valve under the hood. i'm confused now lol
Turd-250 is offline
post #10 of 28 (permalink) Old 03-27-2015, 09:50 PM
Administrator
Zmann's Avatar
He has a pre bypass truck
DTR's Donation page
RIP DTR Ron
Zmann is offline
