Puncture wound to bell housing! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-26-2015, 07:14 PM Thread Starter
Mulepick's Avatar
Changing the fuel filter today and I noticed that there is a 0.5" puncture wound to what I'm calling the bellhousing. That is, the waffle pattern area between the transmission pan and the oil pan.
I never noticed any fluid running out or dripping and I have no idea how long ago it happened.
Should I just drive the truck off a cliff now, seal it with some type of liquid aluminium or something in the middle.
Sidenote: I noticed what I guess to be the inboard bearing seal on one of the front wheels loose and spinning around. Choose from above options as well.
Thanks in advance for all informed opinions.
Bob
2006 Lariat crew cab shortbed 6.0PSD
Mulepick is offline
post #2 of 7 (permalink) Old 03-27-2015, 12:47 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Puncture wound to bell housing!
There is no fluid inside the bellhousing, so don't expect it to leak. You can do whatever you like with it. You can even ignore it, it won't cause a problem.
I've seen this happen when something gets into the bellhousing. It can get caught by the ring gear and thrown hard enough into the housing to make a hole. Does it look like the puncture came from inside?
Mark
Mark Kovalsky is offline
post #3 of 7 (permalink) Old 03-27-2015, 01:09 AM Thread Starter
Mulepick's Avatar
Big relief to hear though I'll try to seal it. Definitely from outside in. Any idea what to use? Seems like a regular two part sealer wouldn't stand up to the heat.
Mulepick is offline
post #4 of 7 (permalink) Old 03-27-2015, 01:37 AM
I agree, leave it alone.
lenzhotrod is offline
post #5 of 7 (permalink) Old 03-27-2015, 01:50 AM
From outside in? I've never seen one like that.
Mark
post #6 of 7 (permalink) Old 03-27-2015, 02:00 AM Thread Starter
Mulepick's Avatar
This truck doesn't get used much (just turned 55k) but when it does it's either to transport a truck camper or to get to very remote places in NV. I probably high centered a rock and took the hit. Preferred sealer for this?
Any thoughts on the rubber ring? Bearing dust seal?
Mulepick is offline
post #7 of 7 (permalink) Old 03-27-2015, 10:58 PM
The rubber plug is to keep crud out of the bellhousing.
Mark
