FICM Replacement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-24-2015, 05:56 AM Thread Starter
Josh923's Avatar
FICM Replacement
Need a new ficm and every shop I've called wants $150 to do it so I'll be doing the job myself.
I purchased a pre-programmed 48v ficm that should arrive soon.
However, I have no idea which tools I'm going to need for the job.
I watched videos, read guides, etc. until I couldn't read anymore, but none of them gave a list of tools needed.
Does anyone know where I can find, or can tell me a list of all of the tools I need as far as socket sizes, etc to complete the job?
It would be very much appreciated!
2004 F250 6.0 Lariat
8" Procomp Lift
Fuel Hostage 18x12
37" Mickey Thompson MT
Straight Piped
JVC/Alpine
RCD
SCT/QuickTricks
Rhino-Lined Ranch Hand
"People should not be afraid of their governments, governments should be afraid of their people."
Josh923 is offline
post #2 of 4 (permalink) Old 03-24-2015, 11:49 AM
whistle tits
ghohouston's Avatar
Re: FICM Replacement
8mm socket, slide the degas bottle out of the way, draining coolant is up to you. Remove front ficm bracket bolts, this bracket has two 8mm bolts that hold it into the air intake, and iirc, a 10mm bolt head on the lower bolts for it. The back bracket bolts I've seen 8mm and 10mm bolts. It's very basic tools needed for the job.
ghohouston is offline
post #3 of 4 (permalink) Old 03-24-2015, 02:58 PM Thread Starter
Josh923's Avatar
You are the man. Thank you so much.
8" Procomp Lift
Fuel Hostage 18x12
Straight Piped
JVC/Alpine
RCD
SCT/QuickTricks
Josh923 is offline
post #4 of 4 (permalink) Old 03-24-2015, 03:21 PM
I Just Break Stuff
I prefer ratchet wrenches.
You can almost break down the entire engine with an 8,10,11,12,13 mm.. and a 30t... torq bit....
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
