need help from expert on 6.0 liter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-24-2015, 05:29 AM Thread Starter
OK truck set for awhile no coolant in it to speak of.i am pretty sure i have head gasket failure. went out to take it to the shop poured water in ran out both freeze plugs behind mounts. so had it towed it sat a couple months no leaks i started it to pull on lift after running about 30-45 seconds it poured oil from freeze out plug holes. some one told me that oil ran through those plugs behind mounts i have engine torn down for head stud kit new gaskets egr delete but is block cracked or is this possible. PLEASE HELP
drinson1883 is offline
post #2 of 9 (permalink) Old 03-24-2015, 03:02 PM
Jackleg Mechanic
mastrkee's Avatar
Re: need help from expert on 6.0 liter
Why are the freeze plugs out, did it freeze and push them out? If so then you my have a cracked block or head.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #3 of 9 (permalink) Old 03-24-2015, 03:03 PM
I Just Break Stuff
If it sat with no coolant to speak of... then filled with water... then sat again .... that things gonna be full of rust. Take that sucker to the machine shop and get it checked out. Block probably needs to be hot tanked... you'll plug oil cooler after oil cooler if it's not clean. As far as oil out of the plugs.... blown oil cooler will mix fluids.
What does your degas bottle look like? There's a lot of variables that need to be put out there.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #4 of 9 (permalink) Old 03-24-2015, 04:02 PM Thread Starter
I'm assuming that it did freeze and push the plugs out.I'm pretty sure that I have head gasket failure since I had already replaced EGR cooler and oil cooler probably five hundred miles before this happened after replacing those items I still had coolant loss and overheating no signs of oil and water mixing though it was puking of the gas bottle still that's how I came to the conclusion it's probably head gaskets my biggest concern is does anyone know if it is possible for oil to come out of those freeze out plug holes anyway besides the block being cracked thanks for all the help everyone.
post #5 of 9 (permalink) Old 03-24-2015, 04:27 PM
Administrator
Zmann's Avatar
wow this sounds bad
oil out the ejected freeze plugs ? maybe your oil cooler split when it froze
but this sounds like it could become a whole motor transplant
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 9 (permalink) Old 03-24-2015, 04:36 PM Thread Starter
it just seemed to me like an awful lot of oil coming out to be just like cracked block and on both sides
post #7 of 9 (permalink) Old 03-24-2015, 04:41 PM
Administrator
Zmann's Avatar
i mentioned split oil cooler
this thing is full of coolant( water in your case ) and oil a rupture would dump oil into the cooling system quickly
just a guess that is what happened
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 9 (permalink) Old 03-24-2015, 05:04 PM
I Just Break Stuff
Zmann... that's kinda what I was thinking too. Never heard of oil with a cracked block... least not that I can recall. Usually hydrolock with coolant.... lots of blow by... low compression with incomplete fuel burn....
Raw oil.... just makes me think oil cooler all day long.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
Lowered 3 Inches
ARPs
Barder stage 3
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
irontx25 is offline
post #9 of 9 (permalink) Old 03-25-2015, 03:14 PM Thread Starter
ok guys it looks to me like the only explanation would be the oil cooler I cut it open to visually inspect it but I could not tell if it was cracked I removed the water pump the impeller was cracked but it does appear that it was pumping oil through the cooling system so as long as the block is not correct which I'm pretty sure it is and we're in good shape all in all thanks for all of your help.
