Manifold air bleed screws? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-20-2015, 06:21 PM Thread Starter
She's ALIVE AgAiN!!!
afFORDable's Avatar
Has anyone heard of these? Not sure if exhaust or intake.
I was informed that to keep a load off of the HPOP while priming, that I should remove the "air bleed screws' from the "manifolds" and crank until oil flows from the reservoirs.
Didn't say what reservoirs either.
I feel like a dumb a$$ over here.
Anyone have any idea whats being talked about? Ever heard of this?
04' (Late 03' engine) Lariat PSD, Auto, Crew cab, 4x4, high idle mod, egr delete, 6.4 banjo, blue spring, coolant filter, ARP studs, 21* HPOP, 6.4 starter, more to come.....
afFORDable is offline
post #2 of 8 (permalink) Old 03-21-2015, 03:55 AM
I Just Break Stuff
Re: Manifold air bleed screws?
Talking about the oil rails.... total bs.... crank on it and go...
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #3 of 8 (permalink) Old 03-21-2015, 04:08 AM
Weatherlite's Avatar
Garage
Simple actually, though I don't think I would want to unscrew both. What he's referring to are the plug in the driver's side wavy oil rail and the ICP sensor in the passenger side oil rail. You can do the passenger side easily enough by removing the sensor, but I don't think I'd want to have the valve covers off when cranking. Anyway, I did this on mine and have heard of many others doing it. However, you have an '03 engine if I recall, so I don't know if you'll have anything like this. In your case, you may just have to crank away.
Weatherlite is offline
post #4 of 8 (permalink) Old 03-21-2015, 06:22 AM
is that the air bleed in the pic?
http://www.powerstroke.org/forum/att...e-photo-5-.jpg
03 Excursion, Banks turbo back, K&N intake, SCT sf2, Scangauge 2, 285/70R17 on Eagle alloys, purchased June '10
robs97z28 is offline
post #5 of 8 (permalink) Old 03-21-2015, 02:38 PM Thread Starter
afFORDable's Avatar
I do have the 03 engine. The oil rails do have the screws in them. Allen key IIR. It makes sense to me to unscrew them and relieve the oil pressure and purge the air in the system without putting strain on the pump itself. Once its flowing and I replace the screws, should I put locktite or something on them?
post #6 of 8 (permalink) Old 03-21-2015, 04:57 PM
I would to prevent any oil leaks!
post #7 of 8 (permalink) Old 03-21-2015, 05:22 PM
I also poured oil straight into the pump before I put the pump cover on. did you check to see if your pump cover is rubbing on the discharge tube?
post #8 of 8 (permalink) Old 03-21-2015, 11:00 PM
I Just Break Stuff
IMO..... this is about as necessary as changing the hpop oil. The more things you remove and the more steps you make, the bigger your margin for error is.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
Lowered 3 Inches
ARPs
Barder stage 3
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
irontx25 is offline
