prices for up pipes and egr delete - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-18-2015, 06:51 PM Thread Starter
06 FX4,4" Rough Country
Bleed Blue's Avatar
just wanting to see what yall think about these prices im paying. truck is currently in the shop getting new up pipes put in bc they were cracked and leaking exhaust fumes into the cab, and while the mechanic is in there he said he would do a egr delete for half price($350 normally $700). $1100 for the up pipes and 350 for egr so around $1450 for all, how does this sound to yall? he said the pipes themselves are around $550. just looking for opinions to see if i got ripped
06 F250 CCLB FX4, 173K, Egr delete, Blue spring, SCT performance tune, AFE cold air, 4" Rough Country, 35x12.50 Cooper STT m/t, Fuel Hostage 18x12 -44 offset, 4"dp into 5" Diamond Eye system
Bleed Blue is offline
post #2 of 10 (permalink) Old 03-19-2015, 02:38 AM
Re: prices for up pipes and egr delete
my .02 is that you got seriously ripped on the up-pipes leaking! That is a relatively common problem and there are people on a few forums that actually re-weld new flex joints in your y-pipe that are better than factory for under $200. The delete, however isn't too badly priced. Just out of curiosity, why did you choose to let a shop fix it?
Ford_Fan1 is offline
post #3 of 10 (permalink) Old 03-19-2015, 02:41 AM
Mike T's Avatar
Garage
Yeah, sounds steep for uppipe replacement.
05 F350 cclb dually, egr delete, blue spring upgrade, coolant filter, cat and muffler delete, scanguage II
Mike T is offline
post #4 of 10 (permalink) Old 03-19-2015, 04:26 AM
Big dumb redneck
6speedSD's Avatar
Garage
I bought a built set of uppipes for less than what he says they cost, and I assume he's putting a factory set back in there. Just sayin....$250 is what I paid for mine if I recall correctly. If he went to Ford and bought the pipes, they probably did cost $550.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #5 of 10 (permalink) Old 03-19-2015, 05:54 PM
matthewd11's Avatar
Thats how much the pipes cost at ford, and Alldata shoulds 5-6 hours labor to change them. So, that sounds about right @ 100/hr (which most shops in my area are).
matthewd11 is offline
post #6 of 10 (permalink) Old 03-19-2015, 06:11 PM
5-6 hours? man thats about 4 times as long as it takes an exspurt.
and that price is way to high. dont go back there dude, they want to ream you and probably everyone else too.
BigDangFord is offline
post #7 of 10 (permalink) Old 03-19-2015, 06:24 PM Thread Starter
Bleed Blue's Avatar
Wonderful. They are ford factory up pipes, and I'm not doing it myself bc Im not mechanically inclined. Everything he's doing has a 2yr warranty on it at least. And he does do great work I've seen/heard from friends. And he said its 5-6 hrs of labor at $80/hr. Oh well. I've also got a bad #3 injector and #8 glow plug but that will be waiting until it has to be fixed thanks to no job and being in school simultaneously.
post #8 of 10 (permalink) Old 03-25-2015, 03:03 AM Thread Starter
Bleed Blue's Avatar
well the truck sure does run better now, def spools up more crisp and it is def louder at wot..5" exhaust at 3300rpm holy cow lol.. also today myself i did the blue spring upgrade and went from 53 to 67psi idling and like 56psi wot. This is really good correct?
post #9 of 10 (permalink) Old 03-25-2015, 03:09 AM
Big dumb redneck
6speedSD's Avatar
Garage
56 is great. Yea, these things scream above 3k rpms!
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #10 of 10 (permalink) Old 03-25-2015, 07:41 PM Thread Starter
Bleed Blue's Avatar
Almost forgot, egt's are down about 200 degrees at wot also. It's hard to make it touch 1200 now and before i would see 1400 sometimes which I do know is smokin hot
