high mile 6.0 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-18-2015, 05:01 AM Thread Starter
high mile 6.0
Hey wanted some thoughts. I have a tuned 6.0 with new heads and studded. Also put sinister upgraded oil cooler on it as well as a delete kit. New radiator water pump and thermostat also. I have 276000 miles on this daily driver and if I can make 300k I'll be tickled. My question is this would I be better off buying a new truck or putting a new engine and transmission in my old truck? It is a 2005 and is super clean. I think I can get a new block and salvage my new heads and the upper end of my engine that has been upgraded and new. Or am I just waiting my time? The 15000 or so still would be cheaper than 50 to 70 K for a new truck. Shoot some ideas my way please! Thanks
weldcar05 is offline
post #2 of 6 (permalink) Old 03-18-2015, 02:43 PM
"Slap hands slap hands"
FlossyB's Avatar
Re: high mile 6.0
No reason for a new engine at all. Drive it the way it is unless your dead set on a cummins conversion or something. You might get 500K out of it you never know.
JB
FlossyB is offline
post #3 of 6 (permalink) Old 03-18-2015, 03:42 PM Thread Starter
Re: high mile 6.0
True. And I have considered the cummins as well. I'm in no hurry. The truck is running strong and has not used a drop of oil. Been a reliable rig.
post #4 of 6 (permalink) Old 03-18-2015, 03:53 PM Thread Starter
Re: high mile 6.0
Well except when the egr cooler went and took my head gaskets with it. Lol. That's when I put the upgraded cooler and delete kits and arp studded my performance heads that I had put on. Also had the bottom end checked out and they said it looked fine. Couldn't tell it had 200k on it by looking. Thanks for the reply!
post #5 of 6 (permalink) Old 03-18-2015, 05:39 PM
Mike T's Avatar
Garage
Re: high mile 6.0
They say the bottom end is bullet proof, unless you have an injector start dumping fuel and cause it to hydrolock, can bend a rod with that situation .
05 F350 cclb dually, egr delete, blue spring upgrade, coolant filter, cat and muffler delete, scanguage II
Mike T is offline
post #6 of 6 (permalink) Old 03-18-2015, 09:12 PM Thread Starter
Re: high mile 6.0
Ya that's what I worried about when we took the pan off. All looked good and the cylinder walls looked good and so did the Pistons. The heads were cracked when we sent them to be checked during the head gasket repair that's how I ended up with the wagner heads. It's been a great truck with all that do e and the sct tuner on it. I sure hope it goes another few 100k!
