Parking Brake Pedal Goes to Floor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-16-2015, 03:20 PM Thread Starter
Hey guys,
When I apply the parking brake, the pedal usually goes to the floor. I can release and apply the pedal and after 2-3 tries it usually grabs. When it grabs it engages immediately and holds tight.
In my searches I've seen people recommend changing the backing plates at each wheel because they're rusted out, and I've also seen people point toward the pedal assembly saying the cable is slipping thru a pawl.
Anybody have this issue and what solved it for you?
Thanks
2005 F250 Supercab Lariat 4x4
ARP Headstuds, blue spring upgrade, coolant filter, Powerslot cryo rotors, Hawk Pads, MBRP catback, Isspro fuel pressure gauge, Stock Tune
DB2005Lariat is offline
post #2 of 7 (permalink) Old 03-16-2015, 07:24 PM
Re: Parking Brake Pedal Goes to Floor
They need to be adjusted.
lenzhotrod is offline
post #3 of 7 (permalink) Old 03-16-2015, 07:39 PM Thread Starter
Nah, really???
Wow thanks. Read the post next time, not just the title
post #4 of 7 (permalink) Old 03-16-2015, 09:29 PM
Slated4Greatness's Avatar
Wow, post #2 and you already have attitude? Most people wait until at least 4-5.. lol
Did you do a visual inspection? It might be worth a shot to have a brake shop give you an estimate to see if you even want to mess with it.
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #5 of 7 (permalink) Old 03-16-2015, 10:24 PM Thread Starter
Did you actually find that response helpful?
If so then my apologies for poopooing all that insight.
I guess a really detailed analysis would something like "broken part needs fixed, then parking brake needs adjusted"
post #6 of 7 (permalink) Old 03-17-2015, 01:42 PM
I never wait until post 4...
Check you parking brake (in cab) assembly. The cable rides on a "wheel" which is really two pieces of sheet metal welded together. I bet they have separated and when you apply the brakes the cable slips into the gap. If i push mine down too hard it will separate the plates and stick on. Since it does eventually work i bet it is the pedal assembly and nothing under the truck.
roc-doc is offline
post #7 of 7 (permalink) Old 03-17-2015, 07:28 PM
Administrator
Zmann's Avatar
good call I was scrolling down to post the same and you had it covered
definitely the pedal actuator since it does grab and work eventually it eliminates all other items
DTR's Donation page
RIP DTR Ron
Zmann is offline
