Cannot get #8 injector to work - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-15-2015, 04:18 PM Thread Starter
I have a late build 6.0 with #8 injector not firing. Been replaced twice to no avail. Cannot find the problem. My only guess at this point is the wiring harness is bad. FICM has even been replaced. Where to turn , please help.
2004 CCSB 6.0..........Sinister EGR Delete, Coolant Filter, glowshift gauges, Scangauge II! Auto Enginuity scanner.
RIch
mo_ten304 is offline
post #2 of 13 (permalink) Old 03-15-2015, 04:41 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Cannot get #8 injector to work
My guess is a wiring issue....either bad wiring in the injector harness, broken connector where it attaches to the injector on the rocker box, etc. You could pull your harness and look it over good for chafing...or even dig deeper and start unwrapping the loom there around #8 connector. The harness is available new, so that's a route you can take as well...never priced it out though.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 13 (permalink) Old 03-15-2015, 05:09 PM
You should be able to do some troubleshooting with the buzz test and swap the plug with a cylinder next to it and see if the problem follows. If you have been buying good injectors, I would agree it's probably the harness.
There are a couple different FICM-Injector harnesses. They run from $175-$225 from a good dealer.
2006 F-250 6.0 Auto CC SB 4x4
charlez is offline
post #4 of 13 (permalink) Old 03-15-2015, 05:22 PM Thread Starter
Thanks guys appreciate the response looks like we will be starting on the electrical and go from there
RIch
post #5 of 13 (permalink) Old 03-15-2015, 06:35 PM
Big dumb redneck
6speedSD's Avatar
Garage
Swapping plugs to another injector is a good idea, but if I remember correct, there isn't enough slack in the harness to swap 6 and 8.
Swapping plugs rules out or confirms wiring/connector issue. If you switch them, and the dead injector moves to 6, then it's confirmed. Not really a good idea to run the truck with plugs swapped though, so you need a quality scanner to test the swap.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #6 of 13 (permalink) Old 03-16-2015, 01:26 AM Thread Starter
Good info thanks
RIch
post #7 of 13 (permalink) Old 03-17-2015, 01:45 AM
bluesbish's Avatar
how do you know that the injector is not firing?
bluesbish is offline
post #8 of 13 (permalink) Old 03-17-2015, 02:29 AM
codykthekilla's Avatar
Garage
It could be compression related, do you have inj. codes? You can unplug ficm relay and turn the engine over, if its not a constant speed/sound then I would suspect compression issues.
2002 F-250 CCSB PSD 4X4, 38R, S&B CAI, Bully Dog GT, 4" Exhaust, 05 head lights and grill, 08 power fold mirrors, tailgate, bumper, tail lights, 2014 chrome steps.
1979 Bronco 4X4, 460, c6, 205
2003 Ranger 2.3 MT 2wd
codykthekilla is offline
post #9 of 13 (permalink) Old 03-17-2015, 03:05 AM Thread Starter
I have an auto enginuity scanner and continued to throw #8 injector code and even disabling the injectors all worked except 8.
RIch
post #10 of 13 (permalink) Old 03-17-2015, 03:06 AM Thread Starter
Well it turns out that there was a bent pin on the FICM got it straight and thankfully zero codes after putting in a new injector.
RIch
