solution kit help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 03-15-2015, 04:14 AM Thread Starter
solution kit help
I have a 07 f250 and i need to do head gaskets. Ive been looking at solution kits from drifferent companys. My question is does the solution kits come with everything thst you need like rocker box gaskets valve cover etc or is all that seperate. Alos if yall have a beter solution on how i should buy these parts please let me know. Im looking for complete head kit with updated egr and oil cooler along with studs.. thanks in advance
07outlawstroked is offline
post #2 of 14 (permalink) Old 03-15-2015, 01:28 PM
matthewd11's Avatar
Re: solution kit help
There are lots of companies that sell complete kits with what you're looking for. Most of the time they do not come with rocker box gaskets. I pieced mine together.
For about 1500$, i got
head gaskets (black diamonds)
studs
egr delete with up pipe
2 new injectors
every seal i touched on the engine (including exhaust manifold gaskets)
cat delete pipe
thermostat
stand pipes
riff raff CAC boots
machine work on the heads
I feel like there is more but that is the jist of it.
matthewd11 is offline
post #3 of 14 (permalink) Old 03-15-2015, 01:58 PM
Administrator
Zmann's Avatar
the 2 injectors and studs would normally be about 800-950 of that 1500
you shopped well if you got all that and heads serviced for 1500
either that or you add up vehicle expenses like Me
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 14 (permalink) Old 03-15-2015, 03:22 PM Thread Starter
I don't see how you got that for 1500. I'm trying to save all the money where I can so I can fix this truck up right. I just bought it for 2k. Needs 4 injectors I'm going to do all 8. Needs headgaskets coolers and water pump. I also have to get the seats redone and truck body work fixed before I bring it home to my wife
post #5 of 14 (permalink) Old 03-15-2015, 03:54 PM
Administrator
Zmann's Avatar
just watch out
a lot of "solution " kits appear to have an OEM oil cooler when in fact they are some under performing aftermarket unit
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 14 (permalink) Old 03-15-2015, 07:24 PM
matthewd11's Avatar
I get employee parts cost at ford. That's how I got everything so cheap. Got studs with gaskets for 535$, injectors for 200 each, machine work for 260$(I know machinist), Egr delete for 60$, plus all the gaskets I touched on removal.
post #7 of 14 (permalink) Old 03-15-2015, 08:32 PM
Administrator
Zmann's Avatar
Originally Posted by matthewd11 View Post
I get employee parts cost at ford. That's how I got everything so cheap..
I just sent you a "BFF" request
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 14 (permalink) Old 03-15-2015, 11:09 PM Thread Starter
where is the best place to get arp studs.? I can also get employee cost and ford but the only problem is nobody at the dealer knows what I need. So I would need help to know exactly what to get
post #9 of 14 (permalink) Old 03-15-2015, 11:14 PM
Mike T's Avatar
Garage
ARP part# 250-4202
05 F350 cclb dually, egr delete, blue spring upgrade, coolant filter, cat and muffler delete, scanguage II
Mike T is offline
post #10 of 14 (permalink) Old 03-15-2015, 11:23 PM
matthewd11's Avatar
Honestly, i bargained with rudys diesel on ebay for the studs/gasket combo kit.
