Worth it - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 03-13-2015, 07:50 PM Thread Starter
Garage
Worth it
The time has come that the injectors needed to be changed on my truck. I am at a crossroads as to do it or get rid of the truck. I have 186k on the original injectors and I have been reading the average life of the 6.0L is 225k. The truck is a great truck and the only thing that needed to be changed while I have owned it is FICM (replaced with bulletproof), HPOP (while in there I had the bulletproof EGR cooler installed) and the turbo crapped out.
That being said, do I change the injectors or dump it?
If I keep it, do i go with factory injectors or aftermarket?
1ststroker is offline
post #2 of 17 (permalink) Old 03-13-2015, 08:30 PM
I Just Break Stuff
Re: Worth it
Do you like your truck?!?#? If so... throw some injectors in it. Are yours in bad shape?!,!
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #3 of 17 (permalink) Old 03-13-2015, 08:46 PM Thread Starter
Garage
Re: Worth it
Yes I enjoy my truck, I just dont want to spend the money if the truck is only going to last another 35k miles.
As for the injectors, I have not had them checked yet (in the next coming weeks) but what I have read about poor performance and poor fuel mileage Im preparing for the worse case scenario.
post #4 of 17 (permalink) Old 03-14-2015, 04:16 AM
Fixing Broken Stuff
toolmangary's Avatar
Re: Worth it
I'll answer your second question. If you keep it use only Motorcraft injectors.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #5 of 17 (permalink) Old 03-14-2015, 10:39 PM
Re: Worth it
Just curious; where did you come up with the 225K mile number?
For bottom end? Top end?
Not saying I'm doubting you...but...it seems low for any properly maintained modern engine.
I could be wrong.
Ask my ex wife.
CMRA 270 is offline
post #6 of 17 (permalink) Old 03-14-2015, 11:29 PM
cfherrman's Avatar
Re: Worth it
Could be right or wrong, we ran 3 6.0s to 200k (and 2 6.4 to 180k) and traded them, they were rough but i believe that little overhaul and they would be like new. My personal 6.0 has 199250
06 f250 personal, 05 bmw x5 wife, 14 f350 srw work
Originally Posted by Zmann View Post
it's a 6.0 nervous goes with it
cfherrman is offline
post #7 of 17 (permalink) Old 03-15-2015, 08:12 PM Thread Starter
Garage
Re: Worth it
The number is just something I googled. This is why I created this post so I can get the real answer. As for maintaining it, the fluid/filters are change between 5k to 6k. Other then the poor performance and economy the truck run perfect.
post #8 of 17 (permalink) Old 03-16-2015, 02:09 AM
matthewd11's Avatar
Re: Worth it
well, i just dumped a crap load of $ into my truck over the last 10000 miles and i have 182,000 on it now.
If the truck is taken care of and fluids changed regularly i see no reason why it wont last.
A new truck will cost alot more than a set of injectors. And if you replace them use nothing but factory. If you have a BPD egr cooler than you are covered there. Has the truck been studded yet? That was my most recent big expense.
matthewd11 is offline
post #9 of 17 (permalink) Old 03-16-2015, 11:33 PM Thread Starter
Garage
Re: Worth it
Unless the previous owner/business (fleet truck) studded it, no. The truck was maintained very well by both myself and the previous.
The truck been great and being my first diesel and reading the horror stories of the 6.0L I will have to say I have been fortunate to have this one.
post #10 of 17 (permalink) Old 03-17-2015, 12:39 AM
matthewd11's Avatar
Re: Worth it
Studs may be the future investment if all that other stuff is done (after injectors).
Is the truck tuned?
