6.0 headgaskets - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-13-2015, 06:53 PM Thread Starter
6.0 headgaskets
I have read to always use oem headgaskets. Called ford and they are 200 bucks per side and comes with bolts. The local parts store has them for 59 per side just the gasket. I do not need the stock bolts I'm installing arp headstuds. The parts store carries felpro gaskets and I was wondering if they was the same as fords.
ash23k is offline
post #2 of 10 (permalink) Old 03-13-2015, 07:12 PM
Re: 6.0 headgaskets
No, but Victor Reinz (Mahle) Black Diamonds are. Less expensive and don't come with bolts.
post #3 of 10 (permalink) Old 03-13-2015, 08:25 PM
I Just Break Stuff
Re: 6.0 headgaskets
I would stick with OEM gaskets. Take it from someone that's had both. I wanna say there was a vendor on here that could get the gaskets only.... can remember who off hand.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #4 of 10 (permalink) Old 03-13-2015, 11:02 PM
Mike T's Avatar
Garage
Re: 6.0 headgaskets
I've been pricing them lately and you can get OEM head gaskets w/o bolts for $150 per side.
05 F350 cclb dually, egr delete, blue spring upgrade, coolant filter, cat and muffler delete, scanguage II
Mike T is offline
post #5 of 10 (permalink) Old 03-13-2015, 11:37 PM
Re: 6.0 headgaskets
Here are OEMs for $283.06 for the pair including stand pipes.
6.0 Head gasket kits
2006 F-250 6.0 Auto CC SB 4x4
charlez is offline
post #6 of 10 (permalink) Old 03-14-2015, 05:04 PM
matthewd11's Avatar
Re: 6.0 headgaskets
I just put black diamonds in my truck. The construction of the OEM and this gasket are 100% identical minus the color of the sealant. They can be bought for about 65$ each. They are HUGE difference from black onyx. These black diamond gaskets are even made in the same plant as the OEM gaskets. Ford does not actually make the gaskets.
matthewd11 is offline
post #7 of 10 (permalink) Old 03-16-2015, 04:16 AM
Jeremy@NoLimit's Avatar
Re: 6.0 headgaskets
Like stated, the OEMs come with new standpipes as well.
post #8 of 10 (permalink) Old 03-17-2015, 08:46 PM
IIvonnyII's Avatar
Re: 6.0 headgaskets
just me but I prefer OEM, especially for a head gasket. made in the same plant doesn't mean identical. look at the mazda tribute and ford escape. same plant, similar but not the exact same. for the $100 more for reassurance.. id do OEM.
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #9 of 10 (permalink) Old 03-17-2015, 09:22 PM
matthewd11's Avatar
Re: 6.0 headgaskets
I had both the OEM and the black diamond side by side and they are exactly the same thickness and construction. I know many prefer OEM, and i was the same way until i saw this gasket. The only difference is the sealant color.
post #10 of 10 (permalink) Old 03-18-2015, 04:16 AM
Re: 6.0 headgaskets
I haven't had an issue with a set of BD gaskets yet. They are in my truck now and I will put another set in it when I build the motor this winter
