Jury says? Yep...HG's.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-10-2015, 10:36 PM Thread Starter
Youtube of my pressure test just now...
Talk me down...tell me I'm nuts and what I'm seeing isn't real.
http://youtu.be/lqxUw8MHJjY
CMRA 270 is offline
post #2 of 9 (permalink) Old 03-10-2015, 10:56 PM
cfherrman's Avatar
Re: Jury says? Yep...HG's....
Your just low on halogen fluid
06 f250 personal, 05 bmw x5 wife, 14 f350 srw work
Originally Posted by Zmann View Post
it's a 6.0 nervous goes with it
cfherrman is offline
post #3 of 9 (permalink) Old 03-10-2015, 11:20 PM
Mike T's Avatar
Garage
How many pounds of pressure is it showing?
05 F350 cclb dually, egr delete, blue spring upgrade, coolant filter, cat and muffler delete, scanguage II
Mike T is offline
post #4 of 9 (permalink) Old 03-10-2015, 11:49 PM
matthewd11's Avatar
I just saw 9 psi??
matthewd11 is offline
post #5 of 9 (permalink) Old 03-11-2015, 12:03 AM
Gee, your turbo doesn't produce much boost!
lenzhotrod is offline
post #6 of 9 (permalink) Old 03-11-2015, 12:06 AM Thread Starter
It will never get to 16lbs...
There is a leak somewhere that's got to be causing that. It DOES build pressure...OR I've got a bad gauge which isn't impossible...the "T" connections seem tight...
It does seem to climb on acceleration and fall with deceleration.
CMRA 270 is offline
post #7 of 9 (permalink) Old 03-11-2015, 12:12 AM
Mike T's Avatar
Garage
I am probably not alone in saying, look for the leak.
Mike T is offline
post #8 of 9 (permalink) Old 03-12-2015, 01:31 AM
Are you driving it under a load or just running the RPM's up while sitting?
post #9 of 9 (permalink) Old 03-12-2015, 05:48 AM Thread Starter
Under load...
CMRA 270 is offline
