6.0 Not Starting - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-09-2015, 04:38 PM Thread Starter
6.0 Not Starting
So I have a 2004 6.0 w/ around 175,000 miles. It has sat for the last month and a half and will not start. I tried to start it in January and again today and both times it wouldn't turn over. I attached the video showing what it is doing. After the glow plugs warm up there is a rattling noise from somewhere in the passenger side of the engine. I have no idea what could cause it not to start. When I turn the key over, the truck makes no attempt to crank as you can see in the video. At the end of the video I show that part that makes the weird noise.https://www.youtube.com/watch?v=y-NldU6-Zk8
astocker300 is offline
post #2 of 7 (permalink) Old 03-10-2015, 12:49 AM
IIvonnyII's Avatar
Re: 6.0 Not Starting
im not sure if that noise is involved with your no start condition. to me that sounds like the heater fan with a bad bearing or something of sorts. do you know you have good batteries? have you had them load tested? if you answer yes to that.. look at your starter , it could have a bad connection so re do those and retry starting it. if still no start i would take the starter out and have it bench tested.
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #3 of 7 (permalink) Old 03-10-2015, 12:54 AM
whistle tits
ghohouston's Avatar
Check all your fuses, starter solenoid, and check battery voltage to start with. And that noise is your vacuum pump.
ghohouston is offline
post #4 of 7 (permalink) Old 03-10-2015, 01:13 AM
+1, yep. Normal operation.
Start tracking the positive wire back from the starter.
post #5 of 7 (permalink) Old 03-10-2015, 01:32 AM Thread Starter
I will give those a try. Thank you guys! Much appreciated
post #6 of 7 (permalink) Old 03-10-2015, 05:24 AM Thread Starter
Is there another location for fuses other than under the steering wheel? And what fuses should I be checking specifically?
post #7 of 7 (permalink) Old 03-10-2015, 07:08 PM
IIvonnyII's Avatar
under the hood on the drivers side. not sure what fuses , that will be in your owners manual. but starter fuses
Admin of BCCR
- 205/100s
- BW S366
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
