6.0 Help! P0281, fuel knock, injector???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-09-2015, 02:24 PM Thread Starter
I was driving my 06 F350 dually home and everything was running great. I was coming up to a red light and when I let off the throttle I heard a pop and then the truck started idling bad, knocking and pouring quite a bit of white smoke out of the tailpipe. I limped home with it but I noticed when I gave it gas the noise would go away and the truck ran pretty decent. I pulled the P0281 #7 Contribution code. Is fuel knock really that loud or do yall think I have bigger problems. I am not off work until Friday to take it apart so I was hoping to get some input before then. The truck sounds like the old 6.9 diesel when it is idling. Some background on the truck: 92K miles, Magnaflow 4 inch exhaust, EGR delete, 03 turbo, S&B Intake, Elite Insanity tune, Head studs, 10" Fabtech lift, 22.5 semi conversion. If it is an injector should I just replace the one or would I be better off upgrading to bigger injectors? Any input would be greatly appreciated.
modular89 is offline
post #2 of 10 (permalink) Old 03-09-2015, 06:43 PM
cfherrman's Avatar
Re: 6.0 Help! P0281, fuel knock, injector????
I do know that a bad injector will not be noticed at higher rpms because the other 7 make up for it
06 f250 personal, 05 bmw x5 wife, 14 f350 srw work
Originally Posted by Zmann View Post
it's a 6.0 nervous goes with it
cfherrman is offline
post #3 of 10 (permalink) Old 03-10-2015, 12:36 AM
Mike T's Avatar
Garage
Is the turbo making boost in a normal manner?
05 F350 cclb dually, egr delete, blue spring upgrade, coolant filter, cat and muffler delete, scanguage II
Mike T is offline
post #4 of 10 (permalink) Old 03-10-2015, 02:10 AM Thread Starter
It did have a low boost code but when I was taking it easy trying to make it home it was still making boost. The problem just started all of the sudden.
post #5 of 10 (permalink) Old 03-10-2015, 11:22 AM
roughneck0913's Avatar
Sounds like the injector needs pulled honestly sounds like a tip broke. Possibly the head I've had quite a few now with tips breaking off. 7-8 have been #7 sadly
Sold---2000 f-250 4x4 cclb 6 pos tuned by cale airdog 250, holding a stock tranny. afe cold air few other tricks under the hood always
2008 F-250 CCSB 4x4 ZF-6 deleted from day 3
roughneck0913 is offline
post #6 of 10 (permalink) Old 03-11-2015, 02:38 PM Thread Starter
I am really hoping it is only an injector
post #7 of 10 (permalink) Old 03-12-2015, 01:59 AM
matthewd11's Avatar
stop driving it now before you melt a piston. Pull that injector and see what happened.
matthewd11 is online now
post #8 of 10 (permalink) Old 03-12-2015, 05:29 AM Thread Starter
It has been parked since it happened. I drove it about 2 miles after it started and parked it.
post #9 of 10 (permalink) Old 03-20-2015, 07:04 AM Thread Starter
Finally got a chance to look at it. The bolt for the injector hold down had loosened up and the injector had come up a little causing the O-rings on the injector to bust. Replaced the injector and the truck runs like new.
post #10 of 10 (permalink) Old 03-20-2015, 10:09 AM
Mike T's Avatar
Garage
If you don't torque those bolts to spec that can happen.
Mike T is offline
