What is on top of my oil filter cap? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 03-08-2015, 10:07 PM Thread Starter
Strokin2004's Avatar
I am not very familiar with engines, learning as I go. While changing the oil today this is mounted to the top of my oil filter cap. It has a single wire going through the firewall. It looks like it goes under the dash.
What is this?? A oil pressure gauge for inside gauges? Oil temp?
The PO had gauges at some point, not when I bought it though.
Thanks
2004 F-250 Lariat 6.0L CCSB FX4, SCT SF3 tuner, dual exhaust, Pro Comp lift, 35x12.50R17 Toyo M/T, Sinister Coolant filter, Airaid Intake.
Strokin2004 is offline
post #2 of 20 (permalink) Old 03-08-2015, 10:17 PM
scott2001's Avatar
Re: What is on top of my oil filter cap?
im guessing their are aftermarket gueages on the inside. that would be the only thing I could thin kof
2008 got a new flex pipe installed. S-b intake, 4in dp back exhaust, gear head tunes All deletes done now.
flow pro hot pipe. CCV mode.
2013 dodge charger
scott2001 is offline
post #3 of 20 (permalink) Old 03-08-2015, 10:49 PM
Administrator
Zmann's Avatar
that's fugly if no gauges go get a NPT plug and a little teflon tap/paste
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 20 (permalink) Old 03-08-2015, 11:02 PM
Professional American, guarding our constitution. Gone, but not forgotten.
Mr_Andy's Avatar
That will become a problem in the future. Replace the cap with a proper one.
Mr_Andy is offline
post #5 of 20 (permalink) Old 03-08-2015, 11:02 PM Thread Starter
Haha I agree, not very pretty and jenky looking!!
Is that for Oil Temp???
post #6 of 20 (permalink) Old 03-08-2015, 11:23 PM
Administrator
Zmann's Avatar
probably psi
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 20 (permalink) Old 03-08-2015, 11:26 PM
Administrator
Zmann's Avatar
Andy brings up a good point the cap may be an issue if it isn't made right there are plenty of good units out there since so many people tap in there for lots of things including bypass filtration so just make sure it has the OEM dimensions inside
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 20 (permalink) Old 03-09-2015, 12:19 AM Thread Starter
It seems to have the correct dims and fits great, filter locks in fine and fits fine, however I am just going to order a new basic plastic one to be on the safe side and not worry about any future issues. Thanks for the info guys.
post #9 of 20 (permalink) Old 03-09-2015, 12:30 AM
Mr_Andy's Avatar
Not just the appearance but with that coffee can mopunted on top of the bolthead/boss to remove it is blocked, so you can only grab it on two sides with the best rounder-outer of all fasteners and IMO most useless of hand tools, an adjustable wrench. There's six sides on that for a reason. Six point sockets.
Mr_Andy is offline
post #10 of 20 (permalink) Old 03-09-2015, 12:55 AM
Administrator
Zmann's Avatar
Agreed
I have to take my oil bypass line and fitting off the cap every time i do an oil change
i want to grab all six sides wit a socket
DTR's Donation page
RIP DTR Ron
Zmann is offline
