Exhaust back pressure/ engine load. Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-08-2015, 03:15 AM Thread Starter
while checking my gauges on my sct live wire, I noticed that the exhaust back pressure was 75-105 psi. And my engine load was 30-56%. While just accelerating normally and normal driving. Are those normal? Thanks.
smitty's_6.0 is offline
post #2 of 5 (permalink) Old 03-08-2015, 06:09 AM
cfherrman's Avatar
Re: Exhaust back pressure/ engine load. Question
I did some checking on the ebp values, ive seen 0-24 or 0-32 being correct. Idle should be .5 psi within maf and barometer readings. I have a issue with my pickup i think my cat is plugged. Mine reads 5 psi high of maf and baro while going up to 50 psi during acceleration. If you had that much pressure i would think you would have all sorts of problems.
06 f250 personal, 05 bmw x5 wife, 14 f350 srw work
Originally Posted by Zmann View Post
it's a 6.0 nervous goes with it
cfherrman is offline
post #3 of 5 (permalink) Old 03-08-2015, 06:13 AM
whistle tits
ghohouston's Avatar
Sounds like both of you may need new ebp sensors... if you have already checked the tube and manifold fittings for soot clogging them. If that doesn't fix it, and map and baro look about the same, it's probably sticky veins.
ghohouston is offline
post #4 of 5 (permalink) Old 03-08-2015, 06:22 AM
cfherrman's Avatar
I checked and cleaned mine, looked new, sticking vanes? Yeah probably, one more thing on my list.
post #5 of 5 (permalink) Old 03-08-2015, 02:14 PM
My back pressure is usually less than double what boost is. Usually more in the neighborhood of 1 to 1.5
9779scott is offline
