Coolant pressure sky rockets but truck drives fine?! HELP!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 03-08-2015, 12:25 AM Thread Starter
Exclamation Coolant pressure sky rockets but truck drives fine?! HELP!!
Hello everyone, so i recently picked up a 2006 F250 with 60,000 miles. and it runs great BUT today i installed a coolant pressure gauge just to monitor everything (already bought the Edge CTS to monitor everything else) so after installing this gauge i took her out for a spin and as i lay into the throttle i watch in horror as this gauge runs past 10, 15, hits 20psi at around 3/4 throttle! so i immediately turn around and park it. the truck was running normal operating temp of 200F if that makes a difference. can't hear any unusual noises, deltas are 3-6 degrees difference and the EGR has been deleted. so my question is, is this indefinitely a blown head gasket? If not what else should i be looking at/for? ANY help would be much appreciated as i have just bought this truck and don't want to have to drop another 3-5 grand on it.
ROOSTA is offline
post #2 of 11 (permalink) Old 03-08-2015, 12:32 AM
Re: Coolant pressure sky rockets but truck drives fine?! HELP!!
sounds like heads to me and if your not doing the work your self then get ready to spend
at least that.does it climb pretty quick on the gauge.
power45 is offline
post #3 of 11 (permalink) Old 03-08-2015, 12:34 AM Thread Starter
Id say quick is an understatement. it takes it maybe 2 seconds to hit around 20psi and thats just easing it up to around 3/4 throttle.
ROOSTA is offline
post #4 of 11 (permalink) Old 03-08-2015, 12:51 AM
matthewd11's Avatar
Stick a fork in it. That's how mine are. I am pulling the cab on mine on Monday. Strange with lowish miles. I have 3 times your mileage. They must have had a cheap tuner on it.
Is it puking yet?
matthewd11 is offline
post #5 of 11 (permalink) Old 03-08-2015, 01:16 AM Thread Starter
where ya havin 'em done at? i live in NC if anyone has any suggestions as far as shops that specialize in 6.0's lemme know!
ROOSTA is offline
post #6 of 11 (permalink) Old 03-08-2015, 03:42 AM
matthewd11's Avatar
I'm a tech I'm doing them myself
post #7 of 11 (permalink) Old 03-08-2015, 04:13 AM
scott2001's Avatar
are you got white smoke coing out the tail pipe. or a lot of pressyure on the degas bottle.
2008 got a new flex pipe installed. S-b intake, 4in dp back exhaust, gear head tunes All deletes done now.
flow pro hot pipe. CCV mode.
2013 dodge charger
scott2001 is offline
post #8 of 11 (permalink) Old 03-08-2015, 04:26 AM Thread Starter
haven't noticed any white smoke at all. as far as degas bottle pressure, i saw it rise to 20psi at 3/4 throttle. now (less than 4 hours later) its already back to zero. i don't know what else could cause such high coolant pressure besides HG's.. open to any suggestions though!
ROOSTA is offline
post #9 of 11 (permalink) Old 03-08-2015, 01:21 PM
matthewd11's Avatar
As long as your gauge is accurate, there isnt anything else, especially with an egr delete.
post #10 of 11 (permalink) Old 03-10-2015, 07:42 PM
I Just Break Stuff
Umm... cracked heads will do the same thing. You shouldn't be hitting 20 psi if your cap is working correctly. Is there any soot in your degas bottle??!?! Can you smell exhaust in it??!
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
