no dome light or door adjar light or chime after xlt to lariat conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 03-04-2015, 09:33 PM Thread Starter
Cpattie
Hey guys.
I am in the process of doing a complete XLT to Lariat conversion in my 05 F250 Crew Cab 6.0L. Below is a list of everything I have swapped from a donor truck.
-Complete dash harness
-Gauge cluster
-Auto climate control
-Power adjust pedals
-All dash switches, cluster menu buttons, power slider, power pedals, headlight with fogs, etc.
I am currently having a problem that the truck doesn't seem to know that the doors are open. I don't get any dome light when the doors open, however I can turn them on manually from the headlight switch. I get no door agjar chime, or key in the ignition, or headlights on etc.. also when I turn the ignition off, and open the door the radio stays on.
I have searched all over, and can't really find anyone with this exact problem. It seem like the items below are common culprits for similar issues.
VSM - (I don't think it's this, all door locks and everything else are find, and it was never unplugged or removed from truck.
Gauge cluster - I have the origingal one, swapped back and forth and have the same issue.
Damaged wire - I have read that there is a wire in the cab wire harness along the floor that is connected to door switches that could cause this symptom if it is corroded or damaged, but don't know how to diagnose.
I have the complete interior out, it is possible the a wire got damaged, but I have been very careful. Also, the cab wire harness is in very good shape, with no corrosion at all.
I greatly appreciate everyone's ideas in helping me diagnose this.
Chris
2005 CCSB 4X4 6.0 XLT
Cpattie01 is offline
post #2 of 18 (permalink) Old 03-05-2015, 12:51 AM Thread Starter
Cpattie
Re: no dome light or door adjar light or chime after xlt to lariat conversion
Also just realized no auto headlights either
post #3 of 18 (permalink) Old 03-05-2015, 02:07 AM
richyrich's Avatar
Accessorie delay fuse
2002
f-250 7.3L powerstroke superduty xlt sc sb 4x4 offroad, pure turbos 360 turbo rebuild kit,
mile marker 449 s/s hub locks, php phoenix 6 position chip, diy 6637 intake, 140k and rollin strong
richyrich is offline
post #4 of 18 (permalink) Old 03-05-2015, 02:20 AM
Administrator
Zmann's Avatar
man thats an asssload of work but I can't figure the issue
the radio not shutting off is obviously because it is not sensing the door being opened
same as the dome light
i would be looking for a connection issue
since it worked before your swapping
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 18 (permalink) Old 03-05-2015, 02:58 AM
dieselpower177's Avatar
Check all your fuses but sounds like maybe the gem you might wanna try getting it reprogrammed
dieselpower177 is offline
post #6 of 18 (permalink) Old 03-05-2015, 03:03 AM Thread Starter
Cpattie
Is the Gem part of the fuse panel on these? I have 2 of them an tried both of them and no change. They do have fullerene part numbers though. Checked all the fuses
post #7 of 18 (permalink) Old 03-05-2015, 03:58 AM
its the box attached to the back of the fuse panel inside the cab on the drivers side you have loosen all the bolts for the fuse panel to get access to it
post #8 of 18 (permalink) Old 03-05-2015, 04:00 AM
i had similar issues with mine when it get wet from a leaking windshield gasket ended up having to replace mine also check for bent pins or corroded
post #9 of 18 (permalink) Old 03-05-2015, 08:52 PM
Administrator
Zmann's Avatar
there is no GEM on your 05
just the VSM /cluster and separate modules
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #10 of 18 (permalink) Old 03-06-2015, 12:55 AM Thread Starter
Cpattie
I'm leaning towards the VSM. I have to differ clusters, the original xlt version, and the replacement lariat. The symptoms are the same with both clusters. Everything worked as it should before I took the interior out.
Is the VSM something that simply needs reprogrammed? Or am I going to have to replace it?
