Disappearing oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-04-2015, 12:55 AM Thread Starter
Tom's 2006 F250's Avatar
Unhappy Disappearing oil
Well I have another issue. Not sure if it is self inflicted. I recently had all 8 fuel injectors replaced due to stiction, poor gas mileage and no hot start.
Well now I am losing oil but do not have any visible oil leaks. We used rebuilt injectors from the Ford dealership.
The truck starts up and has been running great. But anytime it sits for a bit on start up it blow out a little bit of white smoke which then immediately goes away.
I am wondering if maybe one or more of the orings on the injectors were damaged during installation. We used plenty of grease when installing and was sure to not bind up the injectors while tightening.
I sure don't want to tear everything back down but I need to figure out where the oil is going. I can say that prior to doing the injectors I was not losing oil.
Could it be from the turbo? CCV? Something else I could be missing?
So not digging all these issues.
Thanks for the information...
EGR delete
SCT tuner
Coolant bypass filter
4.5" Rough Country lift kit with 35x12.50x18" tires
Blue fuel regulator spring
(2) 12" Pioneer subs with 1200 Watt Pyle amp
Tom's 2006 F250 is offline
post #2 of 9 (permalink) Old 03-04-2015, 12:59 AM
matthewd11's Avatar
Re: Disappearing oil
I'd start by checking the CCV and the turbo. Pull the down pipe off and see if its wet with oil residue.
The only thing i can think of is that you could have pinched an O ring, but i would think it would be smoking blue from the oil mixing with the fuel.
How much oil are you losing? White smoke is either fuel or coolant, not oil.
I assume no knocking noises (fuel knock)?
matthewd11 is offline
post #3 of 9 (permalink) Old 03-04-2015, 01:00 AM
hmm, sounds like maybe you got an issue with the o rings sealing??? did you change injector cups too?
BigDangFord is offline
post #4 of 9 (permalink) Old 03-04-2015, 01:14 AM Thread Starter
I am losing maybe a quart a week. I am not 100% sure on that just yet. Is the down pipe the one that goes to the intercooler? If yes then I do see quite a bit of oil in it. Also quite a bit of oil at the turbo inlet from the air filter where the CCV hose connects. Not sure what fuel knock is. I just replaced the entire injector. Did not touch any cups
EGR delete
SCT tuner
post #5 of 9 (permalink) Old 03-04-2015, 03:58 AM
Jeremy@NoLimit's Avatar
Downpipe=exhaust
post #6 of 9 (permalink) Old 03-04-2015, 01:24 PM Thread Starter
So that equals turbo seals?
EGR delete
SCT tuner
post #7 of 9 (permalink) Old 03-06-2015, 07:55 PM
Big dumb redneck
6speedSD's Avatar
Garage
IF there is oil in your dowpipe (big exhaust pipe coming off the back of your turbo).
I'd think if you damaged Orings, you'd have some running/starting issues.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #8 of 9 (permalink) Old 03-07-2015, 04:40 PM
IIvonnyII's Avatar
is there any oil making it into your coolant? only places oil can go is on the ground , into the coolant , or be burnt through turbo seals or injector o rings or other cracks / damage.
If it was a pinched O ring I would assume it be not running quite right.
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #9 of 9 (permalink) Old 03-07-2015, 09:23 PM Thread Starter
So I pulled the EGR valve delete cap off the intake and there appears to be quite a bit of oil in the intake. I think I have excessive oil coming through the CCV pipe into the turbo and then into the intake and burned off
EGR delete
SCT tuner
