heating/AC blower - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-03-2015, 10:28 PM Thread Starter
rtc0360's Avatar
heating/AC blower
Everyone,
Have a question concerning my heating/AC blower. My blower comes on but seems that on high the blower is barely moving any air. There is an aftermarket blower on the unit that I suspect is the culpret. Plan on pulling it out and checking the blower for switching to different speeds. I suspect it is not switching to high. Read about the resistor being bad, thinking about replacing for good measure. My hope is it that this motor they (previous owner) installed is the problem. Looks like it may be off of another ford vehicle. My experience with ford AC/heat systems normally blow your head off your shoulders. Any advice?
Thanks
rtc0360 is offline
post #2 of 7 (permalink) Old 03-03-2015, 11:16 PM
Jackleg Mechanic
mastrkee's Avatar
Re: heating/AC blower
I had a 99 F350 that got like that and discovered that a plastic bag had been sucked up into the air pickup side. Once it was removed it blew like normal. hope yours is as simple to fix as mine was!
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #3 of 7 (permalink) Old 03-04-2015, 01:47 AM
whistle tits
ghohouston's Avatar
If everything else checks out, pull the blower motor out, and take a look back inside the housing, at the heater core. Use a flashlight and mirror. The fins will get completely packed up with dirt, and will turn to mud, resulting in very poor air flow.
Usually if the blower motor resistor is bad, only one speed works.
ghohouston is offline
post #4 of 7 (permalink) Old 03-04-2015, 12:15 PM Thread Starter
rtc0360's Avatar
Thanks will pull it this weekend. Let you know what I find.
rtc0360 is offline
post #5 of 7 (permalink) Old 03-11-2015, 03:56 AM
I Just Break Stuff
Does it blow normal on every other setting?!?! If it does, and is only weak on 1 setting, it's your blower motor resistor pack.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #6 of 7 (permalink) Old 03-11-2015, 07:02 PM Thread Starter
rtc0360's Avatar
didn't get a chance to look at it this past weekend. Will look this weekend.
rtc0360 is offline
post #7 of 7 (permalink) Old 03-15-2015, 01:31 AM Thread Starter
rtc0360's Avatar
Checked blower and all seems to work well. I have a cover off that may be causing the lack of air out of the vents. I will replace cover and report back.
rtc0360 is offline
