Procedure for jacking/barring 6.0 engine over - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 03-02-2015, 01:27 AM Thread Starter
I have an '03 F250 6.0 that just blew the EGR with a resulting hydrolock. I was able to get all the glow plugs out without breaking anything. My question is how do you bar/jack this engine over by hand? Do you have to remove the fan/fan clutch assembly to get at the center pulley?
cscheide is offline
post #2 of 2 (permalink) Old 03-02-2015, 01:46 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Procedure for jacking/barring 6.0 engine over
Just get on one of the bolts in the damper on the crank. There are 4 bolts there, but you can turn it over by using one of them. 18mm I think they are.
Oh, and put the truck in neutral.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
