Blown EGR cooler? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-28-2015, 07:59 PM Thread Starter
Blown EGR cooler?
I'm pretty sure this is a blown egr cooler. Let me know what you experts think. I cleaned the vlave 6000 miles ago. Did not really notice a loss in coolant back has not been to long since I found a hole in my coolant tank.
Currently in process of installing MBRP 5" turbo back exhaust.
6.0 115000 miles
SCT live wire ID ECONOMY/extreme street
Stock.. :/
bigriggs22 is offline
post #2 of 9 (permalink) Old 02-28-2015, 08:37 PM
Administrator
Zmann's Avatar
Re: Blown EGR cooler?
that picture is no real indicator
a slightly gooey substance is normal
usually you want to park it nose down for the night then look for an accumulation of coolant
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 9 (permalink) Old 03-01-2015, 09:40 PM Thread Starter
I did have the rear jacked up about 1-2 feet for about 2 hours before i pulled the valve. I was told that this should be very dry and not wet/shinny. But my source could be wrong. Also i am 99% sure i have blown head gaskets... Anyway looks like ill be deleting the EGR system in the next few months hopefully. Is there any way to delete the valve and still allow the fan to operate correctly?
post #4 of 9 (permalink) Old 03-01-2015, 11:18 PM
matthewd11's Avatar
Mine looks like that (maybe not as wet) and it has never lost a drop of coolant. Never smoked, either.
matthewd11 is offline
post #5 of 9 (permalink) Old 03-01-2015, 11:29 PM
Jackleg Mechanic
mastrkee's Avatar
leave the valve laying on top of the motor and leave it plugged in. That'll solve the fan problem.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #6 of 9 (permalink) Old 03-01-2015, 11:47 PM
Administrator
Zmann's Avatar
agreed
if you have the fan issue that is the fix
and agreed the oily soot is what I have seen as normal
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 9 (permalink) Old 03-02-2015, 02:02 AM
whistle tits
ghohouston's Avatar
Even better than leaving the valve laying there, you can bolt it to the back of the cast intake elbow. There is a threaded hole already there (same size bolt as the egr valve). The valve will sit directly above where it was in the intake, looks clean, and still plugs in, no check engine light, and fan clutch operates like it should.
ghohouston is offline
post #8 of 9 (permalink) Old 03-02-2015, 03:26 AM
Administrator
Zmann's Avatar
nice
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 9 (permalink) Old 03-02-2015, 05:08 AM
Banned
if you think you have cooler issues i would do a head pressure test.that soot really looks to be too wet.i personally think that you have other problems and if caught now could save you money per say.
equalizer is offline
