6.0 no start help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-28-2015, 05:08 AM Thread Starter
6.0 no start help
I have that 05 The truck will not crank turns over it has oil pressure the high-pressure oil pump is working what else do you all think it could be
Jb21 is offline
post #2 of 5 (permalink) Old 02-28-2015, 05:32 AM
95 5speed's Avatar
Re: 6.0 no start help
It could be the EGR going out. A buddy of mine had the same issue with his and I have no idea how it relates to the EGR but that's what it ended up being
1995 F250 7.3 5 speed 4x4
Dana 60, Ranch hand, straight pipe, intake and lots of little mods
95 5speed is offline
post #3 of 5 (permalink) Old 02-28-2015, 06:01 AM
Banned
what are your pids "readings".i will give you a few things to look at.have you done any up dates on your truck such as dummy plugs oil tubes and stc fitting.if you have not i would check those.i would also check the ipr.pull the ipr out and see if the screen has a tear in it or crap on the screen.
have you done an air test if you need further help feel free to pm me.
equalizer is offline
post #4 of 5 (permalink) Old 02-28-2015, 06:56 AM Thread Starter
At first we thought it was the high-pressure oil pump took the IPr out and there was no screen put a new IPr in it and I think it's got 1400 PSI or something like that
Jb21 is offline
post #5 of 5 (permalink) Old 02-28-2015, 12:29 PM
matthewd11's Avatar
Did you find the old screen? Its probably stuck in the pump.
matthewd11 is offline
