bolt pattern - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-27-2015, 06:32 PM Thread Starter
bolt pattern
Is the bolt pattern the same on an 06 dually as a 2011
9779scott is offline
post #2 of 4 (permalink) Old 03-01-2015, 11:17 PM
Mike T's Avatar
Garage
Re: bolt pattern
I did a little research, looks like 05-10 is the same, 8x170 bolt pattern..
05 F350 cclb dually, egr delete, blue spring upgrade, coolant filter, cat and muffler delete, scanguage II
Mike T is offline
post #3 of 4 (permalink) Old 03-02-2015, 01:48 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: bolt pattern
In 05, DRW trucks went to 8x200. SRW trucks stayed 8x170. No idea if the 2011 is the same, but I assume it is.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #4 of 4 (permalink) Old 03-05-2015, 08:36 PM Thread Starter
Re: bolt pattern
Thanks, I knew mine was 8x200 but I found a guy with a set of rims for a 2011 and he thought his were 170.
