Flush - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-26-2015, 08:56 PM Thread Starter
Flush
What is the best antifreeze to but back in after flush. What about cat antifreeze ?
Parker95 is offline
post #2 of 9 (permalink) Old 02-26-2015, 11:21 PM
Ditch Digger's Avatar
Re: Flush
Flush with distilled water. I like CAT concentrate.
Part number 238-8647.
About $24 per gallon
2006 F450 13,000# Service Truck, Sct live wire /65hp tow tune. Baldwin BF1212 primary fuel/water seperator, Cat 1R-0750 secondary fuel, CAT ELC.
Ditch Digger is offline
post #3 of 9 (permalink) Old 02-27-2015, 12:43 AM Thread Starter
Re: Flush
Thanks I was told about it but wanted someone's thuats
Parker95 is offline
post #4 of 9 (permalink) Old 02-27-2015, 02:38 AM
Re: Flush
Rotella ELC, Cat ELC, etc. etc. There are actually quite a few acceptable ELCs out there, but not many places carry them. I can't remember off the top of my head, but Napa has an acceptable ELC. I have Peak Final Charge in mine. Heck, Navistar/International coolant. What you want to look for is a silicate free ELC. Incidentally, the Ford Gold OEM coolant is not silicate free. Not good.
There is nothing special about name-brand Cat coolant, it just is a silicate free ELC. Get it if you want, all acceptable coolants are ~$25 per gallon for the concentrate stuff (which you must use; no 50/50). Final Charge can be bought from Oreilly, but it's probably a special order item.
post #5 of 9 (permalink) Old 03-01-2015, 02:56 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Flush
The Final Charge in mine as well. Was the easiest one for me to get. Had to be ordered, but it's always there within 24hrs. Just make sure you see "EC1 rated" on the jug somewhere.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #6 of 9 (permalink) Old 03-08-2015, 10:21 PM
scott2001's Avatar
Re: Flush
I use prestone elc from wally world
2008 got a new flex pipe installed. S-b intake, 4in dp back exhaust, gear head tunes All deletes done now.
flow pro hot pipe. CCV mode.
2013 dodge charger
scott2001 is offline
post #7 of 9 (permalink) Old 03-08-2015, 11:45 PM
Re: Flush
Black bottle or yellow bottle? I hope the black bottle, because the yellow bottle Prestone "Extended Life Coolant" is not acceptable for diesel engines (and certainly not for 6.0 PowerStrokes).
The reason I mention it is because I don't believe Walmart sells the Prestone Command coolant (diesel coolant, Cat EC-1 approved, silicate free, etc.). I've never seen it in the store, I just looked and couldn't find it in the online store.
Just to be clear, this Prestone coolant (even though it's sold as an "ELC") is not acceptable: Prestone Extended Life Antifreeze/Coolant – Walmart
This Prestone Command coolant is perfectly fine: Prestone Command® Heavy Duty Extended Life Antifreeze / Coolant
post #8 of 9 (permalink) Old 03-09-2015, 12:30 AM
matthewd11's Avatar
Re: Flush
Zerex cummins/cat coolant is going in mine. 13$/gal at napa
matthewd11 is offline
post #9 of 9 (permalink) Old 03-09-2015, 02:44 AM
cfherrman's Avatar
Re: Flush
ive used similar (federated global, add to anything i bet its exactly the same) to top up the pickups and the heavy truck diesels at work for years, funny stuff
06 f250 personal, 05 bmw x5 wife, 14 f350 srw work
Originally Posted by Zmann View Post
it's a 6.0 nervous goes with it
cfherrman is offline
