6.0 lagging blowing white smoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 02-24-2015, 11:00 PM Thread Starter
I have a 05 6.0 and recently has started to hesitate when I leave from stop and has no power and blows white smoke. Doesn't happen all the time but getting more frequent. Could this be bad fuel or injector problem. Thinking about pulling EGR valve and cleaning, would this help?? Thanks in advance...
Tapinto1 is offline
post #2 of 13 (permalink) Old 02-25-2015, 12:07 AM
Jackleg Mechanic
mastrkee's Avatar
Re: 6.0 lagging blowing white smoke
Yes, clean the EGR valve and the EBP sensor and tube. That'd be a great place to start.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #3 of 13 (permalink) Old 02-25-2015, 02:12 AM Thread Starter
Thanks, I'll check them out...
Tapinto1 is offline
post #4 of 13 (permalink) Old 03-01-2015, 02:59 AM Thread Starter
Finally above 20 deg. and pulled EGR and cleaned it, EGR was full of black soot... and truck still hesitates and blows white smoke. Can't get over 10 mph sometimes and seems to do when taking off from a stop. I'm trying to do what I can because there is no diesel mechanics by me I trust besides the ford dealer and trying to avoid that.
Tapinto1 is offline
post #5 of 13 (permalink) Old 03-01-2015, 03:15 AM
EA - Eggfarts Anonymous!
Turd-250's Avatar
did you check out the EBP tube and sensor? another easy one would be the MAP sensor & hose.
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #6 of 13 (permalink) Old 03-01-2015, 07:42 PM
matthewd11's Avatar
where are you located?
matthewd11 is offline
post #7 of 13 (permalink) Old 03-01-2015, 07:47 PM
whistle tits
ghohouston's Avatar
Coolant level low? Still have the egr cooler?
ghohouston is offline
post #8 of 13 (permalink) Old 03-03-2015, 03:21 AM Thread Starter
I'm in northern Illinois, I've been watching coolant level and has lowered a little. I have a new EGR valve coming tomorrow. Also checked Map sensor hose on pass. side of engine, cleaned it up and put back. Can't get to other side because of weather, garage isn't large enough... Truck is stock accept ARP head bolts and gibson exhaust.
Tapinto1 is offline
post #9 of 13 (permalink) Old 03-03-2015, 12:00 PM
whistle tits
ghohouston's Avatar
The egr valve won't stop the burning coolant issue. Sounds like your cooler ruptured, or you have blown head gaskets.
post #10 of 13 (permalink) Old 03-04-2015, 02:55 AM Thread Starter
EGR replaced and oil change.. Now no boost, turbo looks good and spins freely. Truck runs and drives just not showing boost.. engine light came on and code was po237 = no boost... ..map sensor on pass side. I removed and cleaned and still nothing, tried old and new egr valve and the same results, Thinking about new trying new sensor, talked to my mechanic and thinks I got a bad egr valve...Last option is the only shop in town that I don't care for... BTW my usual mechanic can't fit in his garage due to truck is dually, really sucks
Tapinto1 is offline
