No Throttle Response (zero) - Pedal Info Please - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-23-2015, 03:35 PM Thread Starter
03 6.0L F350
Completely dead pedal while driving, truck idles. Turn off and restart it will work fine for a short time and then cut out again, might be 1 minute or 2 hours. I had this happen about 4 years ago and the dealership sunk me for a ton of money replacing the pedal (adjustable) and replacing the EGR which I was sure was fine due to my maintenance of it but couldn't prove at the time, but I digress.
I only have 90K miles on this truck and the pedal was replaced probably ~ 65K. I also am not getting any codes according to my SCT tuner and the tune I have has had the EGR shut off anyway so I am fairly sure that isn't it.
I would like to replace the throttle position sensor but don't know if that is possible without replacing the entire pedal which is expensive and I assume not simple. Can the sensor be replaced by itself? Anyone know what the sensor part # is or if there is a link to a tutorial showing how?
Thanks for your time, it is appreciated.
BLSFrederick is offline
post #2 of 6 (permalink) Old 02-23-2015, 04:00 PM
Administrator
Zmann's Avatar
Re: No Throttle Response (zero) - Pedal Info Please
be nice if you could read the deep codes a dead pedal can happen for other reasons
and your right the adj pedal is sold as an assembly and pricey
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 6 (permalink) Old 02-23-2015, 07:53 PM Thread Starter
I keep hearing you have to buy the whole assembly but the prices I am seeing vary by hundreds of dollars. I don't know how to verify this as the correct part #. 3C3Z9F836BA
post #4 of 6 (permalink) Old 02-23-2015, 10:42 PM
Administrator
Zmann's Avatar
there is a non adjustable pedal unit also so you may be seeing that
i still wouldn't buy one till i knew it was the issue last guy i knew had one shipped to Germany and it was not the issue it was just a shorter ref voltage wire
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 6 (permalink) Old 02-26-2015, 01:09 AM
Big dumb redneck
6speedSD's Avatar
Garage
https://www.motorcraftservice.com/pu...15/V4C5061.HTM
Try this. Down the page, section AG15...
Gives acceptable ranges for your APP (accelerator pedal position sensor). You just ohm across pins on the pedal itself.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #6 of 6 (permalink) Old 02-26-2015, 01:19 AM
Administrator
Zmann's Avatar
i need to save that info
thx
DTR's Donation page
RIP DTR Ron
Zmann is offline
