Is it odd? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-23-2015, 02:09 PM Thread Starter
She's ALIVE AgAiN!!!
afFORDable's Avatar
Is it odd?
Is it odd that my early 04 6.0 doesn't have exhaust manifold gaskets?
As long as Ive had the truck it never has had them? Are the necessary?
Ive noticed no exhaust leaks of any sort in any portion of the system....
04' (Late 03' engine) Lariat PSD, Auto, Crew cab, 4x4, high idle mod, egr delete, 6.4 banjo, blue spring, coolant filter, ARP studs, 21* HPOP, 6.4 starter, more to come.....
afFORDable is offline
post #2 of 5 (permalink) Old 02-23-2015, 02:46 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Is it odd?
My 05 had none when I pulled the heads. Put a set on when I put it back together though.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 5 (permalink) Old 02-23-2015, 02:53 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: Is it odd?
7.3's didn't come with gaskets either, but you can buy gaskets for both engines from the dealer.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #4 of 5 (permalink) Old 02-23-2015, 03:37 PM Thread Starter
afFORDable's Avatar
Re: Is it odd?
Are gaskets a necessity though? Ive had no exhaust leaks from the system and Ive pulled it apart twice now....
post #5 of 5 (permalink) Old 02-23-2015, 04:23 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Is it odd?
Well if they aren't coming with them from the factory, then I'd say they aren't a "necessity". I put a set on mine because they are cheap, and it's a place that "can" leak, and while the heads were off and easily accessible, figured why not. Much easier than trying to do it through the wheel well.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
