Anyone have a known good HPOP? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 02-21-2015, 02:33 AM Thread Starter
She's ALIVE AgAiN!!!
afFORDable's Avatar
Looking for a known good HPOP for EARLY 04 6.0 PSD.
Let me know if you have one and what you want for it. I'll pay shipping.
Thanks
04' (Late 03' engine) Lariat PSD, Auto, Crew cab, 4x4, high idle mod, egr delete, 6.4 banjo, blue spring, coolant filter, ARP studs, 21* HPOP, 6.4 starter, more to come.....
afFORDable is offline
post #2 of 25 (permalink) Old 02-21-2015, 11:32 AM
Weatherlite's Avatar
Garage
Re: Anyone have a known good HPOP?
I take it you found out yours can't be rebuilt?
Weatherlite is offline
post #3 of 25 (permalink) Old 02-21-2015, 03:03 PM Thread Starter
afFORDable's Avatar
Joey, over at Terminator Engineering, said that the body is bad. However, Pat, over at Diesel Guru, says that he may be able to rebuild it and repair the body and rebuild the pump as well as rebuild my IPR valve. Hes going to charge to rebuild the pump of course but is going to rebuild the IPR for free with the pump service. However, that's all dependent on how bad the pump is. Once Joey gets it back to me, Ill send Pat some pictures and see what he has to say. Fingers crossed.
post #4 of 25 (permalink) Old 02-23-2015, 05:33 AM
I would love to hear about your experience with Pat goes. His up grades for the early pumps seems to be really awesome. His mods probably would have kept my hpop from failing last year.
03 Excursion, Banks turbo back, K&N intake, SCT sf2, Scangauge 2, 285/70R17 on Eagle alloys, purchased June '10
robs97z28 is offline
post #5 of 25 (permalink) Old 02-23-2015, 01:58 PM Thread Starter
afFORDable's Avatar
I will post my results back here. I am still waiting on my pump to get back from Joey, who unfortunately was not able to help due to some gouging in the pump body. Im not certain that Pat will be able to help either but Ive sent the picture to him and we will see what he has to say. Here is what the pump looks like inside.....
post #6 of 25 (permalink) Old 02-27-2015, 04:43 AM
did you get your pump back yet?
post #7 of 25 (permalink) Old 02-28-2015, 07:31 PM
Banned
i think that could be fixed with some aluminum brazing rod and then cnc'd to spec.you have to really clean the aluminum and then heat it enough to wipe the aluminum brazing rod acrossed it.
there is a video on you tube that shows how the guy welds to pieces together and it will amaze you.but it's worth a try i would think but i don't know how it will turn out because it looks like the pump housing is cast.
equalizer is offline
post #8 of 25 (permalink) Old 02-28-2015, 07:32 PM
Banned
if i have time i will try to make a video fixing something simular.
post #9 of 25 (permalink) Old 02-28-2015, 07:48 PM
Banned
How To EASILY Repair Holes In Aluminum - YouTube
he uses a map torch i think and as you can see as the aluminum gets hot you simply wipe the rod over the area and let it cool on it's own.then put it in the cnc and true every thing up and you have a good housing again.
post #10 of 25 (permalink) Old 03-12-2015, 02:11 PM Thread Starter
afFORDable's Avatar
I have spoken with Pat AKA Diesel Guru. Really nice guy and willing to talk things out and alleviate worries. I sent him the pic above and he stated that it was a common anomaly in the early 6.0 pumps. He also stated that there is a thrust plate that covers and seals that entire area. I have sent my pump to him which he has confirmed as a good rebuildable pump. He is charging $575 for the pump fix, 21* modification and return. He also rebuilds your IPR valve for free with this service. I am waiting for him to get back with me and my return pump and IPR. I will let you guys know how things go from there.
Equilizer......I don't know how to weld....unfortunately. Really need to learn though. And certainly don't know anything about a CNC. Pat has stated something to that effect for my pump though but I believe he is going to send me a previously rebuilt pump and work on mine for resale when he gets the time.
