intermittent missing and sluggish throttle - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 02-20-2015, 05:46 PM Thread Starter
New to 6.0 but not to diesels. I have done a pretty good bit of searching but can't seem to find what I am looking for. I have an 04 6.0 stock afaik with approx 260k. It ran fine when I bought it about 4 months ago. Recently it has started intermittently idling rough. The rough idle is accompanied by missing and sluggish throttle. I bought a scan gauge 2 and have been monitoring things. While the problem is occuring Ficm voltage never drops below 46.5. Ebp seems higher. Ect and eot delta gets higher but still within 15 degree limit. Icp doesn't respond instantly to throttle like it normally would.
I haven't gotten a chance to check fuel pressure but both fuel filters have been changed within last 2 months and have maybe 1000 miles on them. Last oil change was about 3k ago done by po. The engine never throws cel.
On a side note when I went to change fuel filters I found a plug disconnected just forward of fuel filter in valley pan. The truck was running fine then and I found nothing for it to plug into so I didn't worry about it.
Any ideas on where to start? I have not monitored ipr or egr while it is happening.
redneckaggie is offline
post #2 of 2 (permalink) Old 02-25-2015, 05:03 AM
Fixing Broken Stuff
toolmangary's Avatar
Re: intermittent missing and sluggish throttle
Your problem is most likely stiction, and with the miles you have a fresh set of injector will to wonders, as long as you use OEM injectors.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
