03 6.0 smoking missing and has slight knock - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-20-2015, 03:56 AM Thread Starter
Exclamation 03 6.0 smoking missing and has slight knock
Today I noticed my truck smoking at idle. It was dark but appeared to be black or maybe blue. It smelled kinda like diesel or maybe oil it was hard to tell. It was idling a little funny also. I unhooked the battery's and let it sit for about an hour. Hooked them back up and it was hard to start and the smoke came back but twice as bad. Was smoking so bad couldn't hardly see the truck. Going down the road it had the power it always had and smoke kinda went away and then it started to have a knock in it when I let of the throttle. When I got home it was still smoking very badly and when I shut it off it made a loud clunking noise and the truck shook. It fired right back up and had a slight knock at first but would come out of it and again when I shut it off it made a loud clunk like it stopped all of a sudden. It may have a very slight miss at idle. I hooked my programer up to it and got the codes p0266 p0284 p0603. The truck has new oil cooler and egr delete
ash23k is offline
post #2 of 5 (permalink) Old 02-20-2015, 04:00 AM
whistle tits
ghohouston's Avatar
Re: 03 6.0 smoking missing and has slight knock
Iirc, those codes are for cylinders 4 and 6, and the po603 is from unhooking the batteries or running a tuner.
ghohouston is offline
post #3 of 5 (permalink) Old 02-20-2015, 01:16 PM Thread Starter
So are those injectors bad? Would two bad injectors make it smoke that badly and still have power. It doesn't seem to have a miss going down the road. Would those injectors make the knocking sound. Or could it be the ficm?
ash23k is offline
post #4 of 5 (permalink) Old 02-20-2015, 02:16 PM
whistle tits
ghohouston's Avatar
I'd bet on the injectors
post #5 of 5 (permalink) Old 02-21-2015, 12:45 AM Thread Starter
So I let the truck all day plugged it. The outside temp was -11 this morning and got up to 22. I dumped some injector cleaner in the tank along with some 911. It fired right up and idled perfect no smoke no miss. Once the high idle kicked in the smoke started but not as bad. Took it for a test truck the truck seemed to run better and the it started missing and smoking goin down the road. Turned around and headed home and it died going down the road. After a few minutes it fired back up but had a miss and smoking. Got it home and at idle it misses and smoke but around 1500 rpm it smooths out and the smoke goes away. Checked the codes and this time I got, p0284, p0336, p0341, u0160, p2614
ash23k is offline
