6.0 EGT problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-18-2015, 07:21 PM Thread Starter
6.0 EGT problems
At an idle when I first start my truck the EGT's sit around 1400. When driving truck makes 24lbs of boost and WOT but the EGT's instantly hit 2000. Even if little throttle is applied the EGT's will climb well over 1600. Could this be a boost leak or a wastegate/ turbo issue. Truck has 4in down pipe back and a cold air ram air intake also 4 inch. The EGT probe is mounted on driver side manifold and installed by ATS. The chip is an edge cts with attitude. Any ideas I'm stuck
Smalls is offline
post #2 of 6 (permalink) Old 02-18-2015, 08:03 PM
mx185sw's Avatar
Re: 6.0 EGT problems
How long as it been doing this.. based on the numbers and the fact the engine hasn't dropped a head gasket yet.. i would wonder if your pyrometer is fubar. I have had a CAC boot blow off on the highway and my EGT dont exceed 1300 (sure they would climb if i let them)... Double check connections etc..
Sean
___________________________________________
2005 F250 Harley CC SB Banks IQ, 4" Exhaust, Banks Techi Cooler with High Ram, Cold Air Intake, Cat Delete,EGR Delete,Coolant Filter,Amsoil Oil Filter Bypass, PHP ECM Rollback, PHP FICM Tuner, WW2,Rancho 9000XL shocks. Firestone Air Springs w/Daystar Cradles. 224K
mx185sw is offline
post #3 of 6 (permalink) Old 02-18-2015, 08:17 PM
At idle I don't know how you could ever get temp like that! Your gauge is lying.
lenzhotrod is offline
post #4 of 6 (permalink) Old 02-18-2015, 11:49 PM
At idle you should be a lot closer to 400. What gauge are you using?
What does it read if you just turn the key on (don't start) after it's been sitting overnight? It should read ambient air temp. Does it?
2006 F-250 6.0 Auto CC SB 4x4
charlez is offline
post #5 of 6 (permalink) Old 02-19-2015, 02:42 PM
JGman141
Jgman141's Avatar
It's a bad probe, I've had this happen to me aswell. Also look into ditching the edge and getting an sct.
Jgman141 is offline
post #6 of 6 (permalink) Old 02-23-2015, 06:48 PM
06 FX4,4" Rough Country
Bleed Blue's Avatar
Yeah at idle my egt's don't even register 400. I have to press the pedal to even get to 400
06 F250 CCLB FX4, 173K, Egr delete, Blue spring, SCT performance tune, AFE cold air, 4" Rough Country, 35x12.50 Cooper STT m/t, Fuel Hostage 18x12 -44 offset, 4"dp into 5" Diamond Eye system
Bleed Blue is offline
