starter issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-18-2015, 01:55 PM Thread Starter
starter issue
I just put a motor in a buddies 05 truck & we are having a problem with the starter hitting the flywheel. any ideas would be great maybe we missed a spacer plate between the starter & the block?. called local dealership & they say there is not a spacer between there. any help would be great
99oilburner is offline
post #2 of 6 (permalink) Old 02-18-2015, 01:57 PM Thread Starter
Re: starter issue
sorry should say flex plate its a auto trans
post #3 of 6 (permalink) Old 02-18-2015, 03:01 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: starter issue
You must have missed the spacer, there is one that goes between the flywheel and crank, it doesn't look like there is one, but it's there. You can pull the transmission out to put it in.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #4 of 6 (permalink) Old 02-18-2015, 03:25 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: starter issue
Or maybe your starter crapped out?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #5 of 6 (permalink) Old 02-18-2015, 03:36 PM Thread Starter
Re: starter issue
there was no spacer between the flexplate & crank. dealership says they don't list a spacer for between there either.
post #6 of 6 (permalink) Old 02-18-2015, 06:59 PM
Fixing Broken Stuff
Re: starter issue
There is a spacer, believe me, it's about a 1/4" thick.
2004 Jetta TDI
1956 F100
