Loss of power when accelerating 6.0 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-17-2015, 02:01 AM Thread Starter
2003 F250 6.0 / when accelerating on hills, noticeable loss of power. Goes into overdrive. Never used to do this. Has a high sounding whine when it does this. It'll drop from70 mph to 50 mph in about 45 seconds or so. Not pulling any trailer. Also noticed that every now and then, it will crank with no start. Then I stomp the accelerator a few times and it starts. No smoke. No codes thrown. Oil change done about 1k ago. Also fuel and air filters. All stock.
drjweb is offline
post #2 of 7 (permalink) Old 02-17-2015, 02:59 AM
Re: Loss of power when accelerating 6.0
Are you sure no codes are present, or is the CEL just not lit? If I were you, I'd start monitoring ICP.
post #3 of 7 (permalink) Old 02-17-2015, 03:50 PM
Yup, as stated above start by checking your ICP pressure at idle and at wot. Also check you ipr % at the same time and report back.
Ford_Fan1 is offline
post #4 of 7 (permalink) Old 02-18-2015, 12:52 AM
Just for my own knowledge what should they be
9779scott is offline
post #5 of 7 (permalink) Old 02-18-2015, 01:56 AM
NYFB. Thats what.
jontheturboguy's Avatar
Also clean out EPB sensor/tube and MAP sensor hose & port.
The mods are dumb for posting in my Sig line. Next time the mods are gonna ban me and be down to a whopping 10 members. I love PSN!!
jontheturboguy is offline
post #6 of 7 (permalink) Old 02-18-2015, 03:54 AM
Definitely! The IRP percent is arguably more important.
Yep, good idea. I've never personally has this problem in my truck, but I've heard many stories of it.
The ICP needs to be more than 500 psi to start. As Ford Fan recommended, look at the IPR percent. Basically, it shouldn't be constantly around 85%. If I understand it correctly, the IPR duty cycle will never be over that. If it's at 85% at WOT, chances the EEC is wanting more ICP than the system can provide.
post #7 of 7 (permalink) Old 02-18-2015, 03:29 PM
Big dumb redneck
6speedSD's Avatar
Garage
You say there are no codes....what are you reading them with?
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.powerstrokenation.com/forums/10-6-0l-power-stroke-technical-info/409026-loss-power-when-accelerating-6-0-a.html
Posted By For Type Date
Ford 6.0 No Power Accelerating_Yaelp Search This thread Refback 10-27-2015 10:00 PM
