Truck is not Starting - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-16-2015, 09:29 PM Thread Starter
Over the last few days my truck has been a little sluggish starting. I had replaced both the batteries about 6 months ago. Last night went to leave truck turned over real slow but started went off came home and tried to leave again about 20 mins later nothing truck would not start just clicked like a dead battery. When driving the Battery volts run from as low as I saw so far 9.4v after starting and they go up to 12.8 and even 13.2 when driving. Checked the FICM voltage earlier on my tuner it was showing 47 v and would go up to 48v and then back down will include picture to make sure I'm looking at the right one . A friend of mine said its possibly the FICM going on its way out that can cause it to drain the batteries as well. Has anyone of y'all experienced the same issue or tell me where to begin to look thanks for the input.
banshee695 is offline
post #2 of 9 (permalink) Old 02-16-2015, 10:13 PM
mx185sw's Avatar
Re: Truck is not Starting
I would double check those batteries.. get them fully charged and load tested. I worked on a friends truck that had similar voltages... and when i load tested the batteries, 1 was bad. it was a year old... we replaced it and and everything is back to normal. Start with ensuring your batteries are ok.
Sean
___________________________________________
2005 F250 Harley CC SB Banks IQ, 4" Exhaust, Banks Techi Cooler with High Ram, Cold Air Intake, Cat Delete,EGR Delete,Coolant Filter,Amsoil Oil Filter Bypass, PHP ECM Rollback, PHP FICM Tuner, WW2,Rancho 9000XL shocks. Firestone Air Springs w/Daystar Cradles. 224K
mx185sw is offline
post #3 of 9 (permalink) Old 02-16-2015, 10:18 PM Thread Starter
Ok thanks will try that
post #4 of 9 (permalink) Old 02-16-2015, 11:13 PM
IIvonnyII's Avatar
you can get bad batteries out of the box, so as said above.. double check they are in good condition. Beyond that I would get your alternator tested aswell, it may not be charging the batteries enough or at all causing your issues.
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #5 of 9 (permalink) Old 02-17-2015, 01:19 AM
Alternator. Check it immediately before driving any longer! Or, just replace it with an upgraded unit. Even terrible batteries will yield more than 13.2 VDC when driving after warm up.
You could completely remove the FICM and you still wouldn't have any cranking issues. However, if you continue to operate it you'll likely cook the FICM and have more problems.
post #6 of 9 (permalink) Old 02-17-2015, 04:37 AM Thread Starter
Thanks for the input everyone gonna check the alternator tomorrow And the batteries
post #7 of 9 (permalink) Old 02-17-2015, 06:28 AM
amdriven2liv's Avatar
Have you scanned for codes?
Check your ground wires while you are looking at things.
That logic power is too low for sure. Ford TSB-09-24-3 discusses that. By the way, what year is your truck?
"I'm hitting easy street on mud tires"
amdriven2liv is offline
post #8 of 9 (permalink) Old 02-17-2015, 06:30 AM
Another thing. Pull the FICM relay and test it and inspect it.
post #9 of 9 (permalink) Old 02-18-2015, 01:13 AM
deereman39's Avatar
Just a reminder check the batterys separate as a bad one will pull down a good one
deereman39 is offline
