help troubleshooting hard start/no power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-16-2015, 07:22 PM Thread Starter
05 6.0 F250. It's been running rough for a while, and last week, it took a bad turn for the worse. Very hard to start, sounds horrible, no power. The local diesel shop said it was a bad FICM. The voltages are good though (47.5-49 at KOEO, cranking, idle and high power). Tested the alternator and batteries; all 3 were bad and have been replaced. I found the exterior plug for injector 8 was loose and reattached it. That made it slightly easier to start, but not a real fix.
I'm getting codes for P0265, P0268, P0274 and P0283 (circuit high, 2, 3, 5, and 8). Can the FICM be still bad if the voltage is good?
bigsteve is offline
post #2 of 8 (permalink) Old 02-16-2015, 09:25 PM
Re: help troubleshooting hard start/no power
Could be possible but the 235 kinda tells me that you should check your FICM connections and make sure they are all secure and snapped. Also could have chaffing either on the ficm harness or injector harness. Heck the pins to make sure none are pushed in or bent. This would be my first course of action.
2006 F350 4X4 CAB CHASSIS w/ Truck Bed
Blue Spring, Mishimoto tstat
Kdavid1 is offline
post #3 of 8 (permalink) Old 02-16-2015, 11:22 PM
IIvonnyII's Avatar
:WHS:
sounds like a ficm harness / connection issue.
how many miles on the truck?
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #4 of 8 (permalink) Old 02-16-2015, 11:59 PM Thread Starter
150k. The connectors seem solid. Is there a way to test the wiring harness in-place?
bigsteve is offline
post #5 of 8 (permalink) Old 02-17-2015, 01:31 AM
IIvonnyII's Avatar
take out FICM and look for chaffing /exposed / melted wires
Admin of BCCR
- 205/100s
- BW S366
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
post #6 of 8 (permalink) Old 02-18-2015, 12:59 PM Thread Starter
I tested the continuity from the middle connector out, through the injector coils and back to the other pin on the connector. I got 1.0 - 1.1 ohms for all 8 (open and close on 2, 3 ,5 and 8), so I don't think it's the harness or connector. I'm guessing something on the logic board of the FICM failed. Sending it in to Ed.
bigsteve is offline
post #7 of 8 (permalink) Old 03-02-2015, 07:27 PM Thread Starter
Got a new FICM from ficmrepair.com (logic board and power boards were both bad. Got the atlas 40 tune), and got an injector 2 high circuit. Replaced it and it's running like a top. Went from 13.5 mpg to 18.5.
bigsteve is offline
post #8 of 8 (permalink) Old 03-07-2015, 04:41 PM
IIvonnyII's Avatar
great to hear that. awesome
Admin of BCCR
- 205/100s
- BW S366
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
