2005 6.0 sometimes no hot start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-15-2015, 09:59 PM Thread Starter
Please bear with me on this one.
A buddy of mine called me yesterday. He told me he had a hot, no start issue. I told him it was probably just an oil leak and I explained to him the symptoms and the cause. He replied back with "It only does the hot no start sometimes." He told me the truck has to sit for about 3 hours before it will fire up again, or if he puts jumper cables on the battery it will fire up right away. He tells me that there is no cranking rpm difference with our without jumper cables. I was also told the batteries load tested fine.
Sorry I am vague and open on this situation. I haven't Had a chance to go check it out for myself yet, and my friend doesn't have a scanner to plug into it and read live data. I have seen lots of hot no start problems, but I think this is the first hot, sometimes no start issue I have heard of. I told him to check all of the battery connections and make sure they are clean and tight.
Anybody have any advice, or have seen this problem before. Your input is welcome. Thanks.
Bryan-R is offline
post #2 of 9 (permalink) Old 02-15-2015, 10:23 PM
Re: 2005 6.0 sometimes no hot start
Check the icp, unlug and see if it starts. Other than that yes hpo leak--do an air test.
does he have something to read live data--you really need that info to diagnose properly otherwise you're shooting in the dark as it could be related to alot of things that are fine cold but loose "traction" when warm.
2006 F350 4X4 CAB CHASSIS w/ Truck Bed
Blue Spring, Mishimoto tstat
Kdavid1 is offline
post #3 of 9 (permalink) Old 02-15-2015, 11:07 PM Thread Starter
Already tried to unplug the iconic with no luck. And unfortunately he does not have a scanner. What doesn't make sense is it will start as soon as he puts the jumper cables on. I would think if it had a bad battery it would drag when it cranks.
Bryan-R is offline
post #4 of 9 (permalink) Old 02-16-2015, 12:53 AM
Gotcha. These trucks do have to reach a certain rpm to kick off as well--but with it starting with jumper cables would lead me to batteries and alt causing low voltage which will kill the ficm and end up damaging injectors. You really need something to monitor live data on these trucks. If not it just like playing Russian roulette. And another upside is you can save yourself alot of money by diagnosing yourself and catching things before they damage more things ( cascade effect)
Kdavid1 is offline
post #5 of 9 (permalink) Old 02-16-2015, 07:11 AM
Thumbs up Re: 2005 6.0 sometimes no hot start
Had this happen on my 6.0. Ended up being the oring on one of the dummy plugs under the valve cover was bad. Ford had an updated one with a Teflon ring on it.
6ohpowerstroke is offline
post #6 of 9 (permalink) Old 02-16-2015, 04:26 PM Thread Starter
I understand the cascade effect. Like I said before, I do apologize for the lack of info. I was just kind of hopping someone has seen a similar problem. I do agree, it seems to be a lack of battery power.
Bryan-R is offline
post #7 of 9 (permalink) Old 02-16-2015, 04:53 PM
05KRSD's Avatar
I think i remember hearing that the dummy plugs and stand pipes will cause a no hot start also.
2005 F250 King Ranch - 4.5 inch lift, Edge Evolution, 35s, studded, custom exhaust, hid kit.
05KRSD is offline
post #8 of 9 (permalink) Old 02-16-2015, 04:55 PM
05KRSD's Avatar
Check this video out and check out other videos he has.
Ford 6.0 powerstroke diesel. No start when hot. diagnostic tips - YouTube
05KRSD is offline
post #9 of 9 (permalink) Old 02-16-2015, 06:18 PM
That's correct on the 05 and up the main offenders are standpipes, dummy plugs, and stc fitting. Baring doing an air test go straight to these and have a look. If no signs there then an air test would have to be done. Typically hot no start is a hpo leak--pretty simple.
Kdavid1 is offline
