"Coolant Leak" Can't locate! Help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-15-2015, 01:46 AM Thread Starter
bennyboy's Avatar
Me again and have new issue. SMH!!!! So I obviously have a coolant leak and it leaks more when the truck is not running. Why is that? But the leak is running down the backside of the motor all the down the bottom of the oil pan drain plug. Where should I check first? Has EGR delete and head studs completed with coolant filtration kit, but don't know if that would be any good info to start with.
bennyboy is offline
post #2 of 7 (permalink) Old 02-15-2015, 02:23 AM
Administrator
Zmann's Avatar
Re: "Coolant Leak" Can't locate! Help
leaks more when cool ?
that happens some times the pressure is off and lets the leak start
check the heater valve and associated lines
the coolant filter tee also a dry paper towel on your fingers can help
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 7 (permalink) Old 02-15-2015, 02:24 AM
Is the egr delete the type with the j pipe and hose connection to the cooler? If so that should be your first place to look.
2006 F350 4X4 CAB CHASSIS w/ Truck Bed
Blue Spring, Mishimoto tstat
Kdavid1 is offline
post #4 of 7 (permalink) Old 02-15-2015, 11:34 AM
PursuitInterceptor
HeavyAssault's Avatar
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #5 of 7 (permalink) Old 02-16-2015, 12:55 AM Thread Starter
bennyboy's Avatar
Yes it has leaked more when in this colder weather when cooled down after running. Thanks man will check out soon as I can.
bennyboy is offline
post #6 of 7 (permalink) Old 02-16-2015, 12:57 AM Thread Starter
bennyboy's Avatar
Will do and I believe it's with the j pipe. Thanks buddy. When I figure out what the issue I will post the after result.
bennyboy is offline
post #7 of 7 (permalink) Old 02-16-2015, 11:24 PM
IIvonnyII's Avatar
yes, J pipe is definitely the first place to look. same thing happened to me, the hose expanded and the hose clamps cut the hose causing a leak that was impossible to tell where it was coming from beside it being damp underneath the turbo/ engine valley
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
