diesel shop said bad ficm? is it? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-14-2015, 04:49 PM Thread Starter
Tried a new shop to troubleshoot my truck. Hard start, rough running, 0-60 in a minute and a half, tops out around 65. It's been running a little rough for a while, but the loss in power started last week. The shop said a bad ficm. I ordered the Dorman power card and was going to change it. I checked the voltage, and it shows 49-50 the whole time. Should I forgo the power card and just order a new ficm, or check something else?
It's giving codes for low circuits on 2, 3, 5, and 8, and high circuits on 2 and 8. Thanks.
bigsteve is offline
post #2 of 8 (permalink) Old 02-14-2015, 05:02 PM
Re: diesel shop said bad ficm? is it?
A: don't use Dorman anything
B: what are the ficm volts koeo,starting,idle, and at 2500
The fact that you have multiple injector codes would lead me to believe it is electical (ficm, ficm connection, injector harness) also how are your Batts and alt?
2006 F350 4X4 CAB CHASSIS w/ Truck Bed
Blue Spring, Mishimoto tstat
Kdavid1 is offline
post #3 of 8 (permalink) Old 02-14-2015, 05:32 PM
Administrator
Zmann's Avatar
that dorman FICM while cheap and Dormans track record sucks seems to be doing ok to get some folks by until they can say send their power supply off to Ed (Dorman= no core IIRC ) or get a BPD unit
but with those voltages I would be concerned it's not the FICM but those codes are like Kdavid said pointing in that direction
however if they guarantee it is the problem then maybe it's worth it depending on price since you know it's not leaving the shop without some fee's anyway
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 8 (permalink) Old 02-14-2015, 08:01 PM
Agreed on the dorman as a get you buy until.
Kdavid1 is offline
post #5 of 8 (permalink) Old 02-15-2015, 01:52 AM
Sounds like injector harness issues to me, are the plugs seated well in the back of the FICM?
knightgang is offline
post #6 of 8 (permalink) Old 02-15-2015, 07:05 PM Thread Starter
Alternator and batteries tested bad. Replaced all and it's acting the same. Going to try the FICM power module, I guess.
bigsteve is offline
post #7 of 8 (permalink) Old 02-15-2015, 08:14 PM
These trucks do have a cascade effect. Bad at and batteries can toast the ficm so it looks like that is the case with yours. Definitely stinks but just how it goes and shows the importance of monitoring things and catching them before they damage more stuff. Don't be shocked if you get the ficm taken care of then have contribution codes come up from toasted injector selinoids
Kdavid1 is offline
post #8 of 8 (permalink) Old 02-16-2015, 05:18 PM Thread Starter
Okay, I tried the replacement power module, and no change. Is there a way to test the logic before I send the FICM off to fixmrepair.com? How can I test the wiring harness?
I really hate to parts swap... I don't have the money to waste.
bigsteve is offline
