Not enough boost - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-13-2015, 11:16 AM Thread Starter
joemx611's Avatar
Not enough boost
i recently did an egr delete, exhaust, intake, turbo back exhaust, amd SCT programmer, I didn't drive the truck much before I did the work but now have noticed Im peaking at 17.11 psi with the turbo. I have checked for possible air leaks but haven't found any, the previous mechanic that drove the truck said the dealership had put a new turbo on the truck not to long ago but when I did the egr delete all but on bolt on the turbo and one bolt on the pedestal where tight if even in the bolt hole (the rest were laying on top the engine) I did check the turbo wheel and it did have some slop in it. My question is, do I need a rebuild on the turbo? Or is there a safety feature on that SCT programmer to keep the truck from over boosting there for only allows it to push 17 psi.
08 6.4 king ranch 4 door long bed, play truck with all the goods
05 6.0 single cab flatbed, bullet proofed work truck
joemx611 is offline
post #2 of 6 (permalink) Old 02-13-2015, 08:12 PM
IIvonnyII's Avatar
Re: Not enough boost
youre only seeing 17.11 psi, what are you using to monitor ? what year is the truck? if its 05+ what does the dash gauge say . How does the truck drive? does it feel like its boosting more and just reading low? you could have a hole / crack / leak in in the hose off the PS of the intake manifold. with the turbo slop, what way is the play? in and out? or side to side
turbo bolts also have a tendency to turn their own way out and fall into the valley thats ok.
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #3 of 6 (permalink) Old 02-13-2015, 10:34 PM
I Just Break Stuff
I would check for cracks in the map hose.... and busted up pipes.
Could have someone power brake it a little while ya look under the hood.. and see if you can see smoke/soot coming from somewhere in the back.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #4 of 6 (permalink) Old 02-14-2015, 01:11 AM Thread Starter
joemx611's Avatar
The gauge on the dash reads just below 20 and the SCT is where I got the 17.11 reading, the truck is and 05 with 126k, it seems to run good but when I tow anything it doesn't seem like it has the ass it should to pull, the reason I mentioned the turbo and pedestal bolts I wondered if maybe it rattled it self out of ballence, the spool shaft has about a millimeter or so worth or slack side to side
joemx611 is offline
post #5 of 6 (permalink) Old 02-16-2015, 11:27 PM
IIvonnyII's Avatar
i wouldnt too much about that play, in/out play is what you really dont want to see. does it smell like exhaust in the cab at all, ever? checked every IC boots?
Admin of BCCR
- 205/100s
- BW S366
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
post #6 of 6 (permalink) Old 02-19-2015, 01:30 AM Thread Starter
joemx611's Avatar
I have noticed a couples times the last couple days an exhaust odor, I'm just gonna pull it all apart and double check all the clamps and hoses
joemx611 is offline
